Results 1 to 7 of 7
Thread: VN Highbeam problem = VERY ANNOYING
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Default VN Highbeam problem = VERY ANNOYING
    Ok i just put in some headlights that i got from the wreakers. Everything seemed fine until my highs go out, then my lows. I had to drive home on a dirt road with only my parkers and hazard lights to illuminate the road!
    Well anyhoo, me and my dad looked at the fuses for ages until we find it was the main lo and hi beam fuse and the smaller 25 amp fuse which had completely melted into the box!
    New box and fuse later they work, until now. Only the hi's have gone out this time but its the same story, 25 amp fuse blown out again.
    I have no idea anymore. This has only started happening since the new lights. I dont want to keep putting in fuses then at night just wait for it to blow out again unexpectadly.
    Any clues?
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    maybe its got somthing to do with the new lights... Globes = bad wattage!
    aZK.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Look at the wires around the connectors - the globes are not problem. When you put the new head lights in you probably disturbed a wire somehow and it shorts out the lights. Turn the lights on and start moving the looms at the back of the lights around abit. See what goes pop.
    and 3 Dangerous non ABS VN's
    VN Wagon
    Feb 2005
    What wattage are the bulbs? I think the standard is 60/55W. People have posted that higher wattage bulbs tend to melt things.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    if it only happened since you put the new lights in, then I would suggest it is a connection problem. But then, why did you change the lights? Trace the wiring, you would probably have an earth problem.
    Visit my Facebook page
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    Quote Originally Posted by Not_An_Abba_Fan View Post
    i HAD to change them. the lows were like parkers and the hi's were like bad lowbeams = almost uselss light.
    Yea maybe its in the connection. I will have to take a look.
    Thanks guys!
    PRH
    PRH is offline
    vp s utility,and a KENWORTH
    Apr 2007
    Mildura Victoria
    G'day
    I would be looking at what wattage globes are in those lights,if they are 130/90 chuck them and fit PHILIPS 50 % brighter 60/55.
    Phillip
  1. Highbeam problem
    By aries_adel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-04-2007, 08:03 PM
  2. Very annoying problem
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 04:22 PM
  3. please help - annoying problem
    By =Calais v8= in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2005, 08:11 PM
  4. Annoying Problem!
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2004, 12:50 PM
  5. Annoying Problem...
    By fourstar82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 05:46 PM
