Results 1 to 13 of 13
Thread: Removing trolley strips and sicaflex tip
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Default Removing trolley strips and sicaflex tip
    Before JC forums had that nasty incident and heaps of stuff was lost (including the thread on my VN) I was having a hard time getting some sicaflex off my driver's door. It was left over when I removed the trolley strips from all the doors. A long thick bead of black sicaflex was left all down my front door.
    I tried a few different things then settled to CAREFULLY cutting it off with a razor blade. In the end this just left me with a really shallow long thick bead of black sicaflex. No help at all.
    People had cautioned me against using thinners on the acrylic paint, so I steered clear of this option. Until tuesday, when I got really sick of those black scars. I grabbed a rag and a spray bottle filled with thinners (this particular one was 'gunwash'), dampened the rag and started rubbing.
    The sicaflex just wiped straight off. I couldn't believe I hadn't tried this earlier. Maybe I took off the outside tiny layer of paint (rag was SLIGHTLY white) but I don't care. The doors are white now, I wiped off all the sicaflex and gave it a quick polish with some Oxipol and another rag. Washed the car (needed it) and that was it!
    So, the moral of the story is: you can use thinners on acrylic paints, just be careful and make sure you wash off any excess. It won't suddenly dissolve all your paint and leave you with bare metal, as I had been led to believe.
    Hopefully this clears some doubts, although anyone in a panel shop will no doubt know this already
    Sam
    WTB: mulberry VN interior parts
    NO CAR ATM.. -.-
    Jul 2006
    yes dont use thinner =D from experience coz it was gona get painted anyway nothing worked soo yea goodluck finding a way to take it off without wrecking the paint.. but i think sum1 on here has done it, he has a white vn berlina with vyss rims
    VN Ute
    Oct 2006
    you can get them off fine with out wreching the paint - it just takes a steady hand to scrape them off and prepsol will melt the remainder or the sealer with a bit of elbow grease and it wont harm your paint at all
    Japanese scientists have created a camera with such speed that they now can photograph a woman with her mouth shut!
    Morton's Avatar
    Fairstar the Funship
    May 2006
    What about acetone? Has anybody had any experience using that?
    edit: that's a stupid question. I have a completely mangled door and a spare door strip standing in my garage. I'll experiment on that later ^^ lol
    The 1972 HQ Kingswood
    VP SS V8 and Toyota Landcruiser
    Aug 2007
    Brunei
    Ha,
    Acetone is the main component of nail polish remover. I used it to clean the paint of the rims of my crown. No paint left!!
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    cit51 - how's that VP of yours going over there in Brunei? Hope it's coming together OK for you!
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I have heard some people's paint responds differently to the thinners, but mine was ok. The doors look a million times better without the black sicaflex all over them now, and they are still painted white even after thinners so I'm happy.
    VN Ute
    Oct 2006
    depends on the kinda of thinner - some have alot more bite than oters, all purpose thinner tends to be a bit nicer - and it your quick it generally will be ok as it needs to soak in, it you take to long however it will melt your paint!!
    prepsol is the best - it just needs a bit more elbow grease
    tonza's Avatar
    tonza is offline Beers & Blastbeats
    '02 VX Exec S2
    Aug 2005
    Brisbane, QLD
    Wheni do this at work i normally use thinners on white cars only. i was told that its ok to use on white painted cars? but yes, drench a rag in prepsol and rub at it, will come off easy. if not, maybe try a caramel wheel (rubber erasing wheel) on an air drill. has worked for me. hope it helps buddy
    Let freedom ring with a shotgun blast
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Do not use a caramel wheel on VN/VP's as they use acrylic paint.
    Caramel wheel creates heat, heat weakens acrylic paint. Heat HARDENS 2pack paint as used in later models, making caramel wheels ideal for VS etc.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Yeah but buffing with a cutting compound creates heat on acrylic too, it still works as long as you don't heat up the one spot for too long. If you're careful you'll probably be OK.
    1991_Vn2nV's Avatar
    Mar 2006
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Fair enough. Stick with some kind of mild thinners then. And have a painter handy just in case anything goes wrong
  1. Removing door/guard strips VR/VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2007, 08:51 PM
  2. Removing Strips off side off car!
    By finnbe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2007, 11:12 PM
  3. Removing Strips off side off car!
    By finnbe in forum VT - VX - VU - WH - V2
    Last Post: 29-08-2007, 10:37 PM
  4. Removing door side strips
    By karlos_1984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 10:40 AM
  5. Removing Door Strips
    By vxsenator in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2005, 04:50 PM
