Hi everyone,
Got a quick question. Well, issue i suppose you could call it.
I have noticed that the seal between the drivers window, and the mirror is not sitting where it should be. The passenger side is fine, but the other one is sticking out, and causing it to leak.
I have seen this on a few VN's before, is it a common problem, and is there a simple fix?
Thanks,
Sam
take the mirror assembly off, wind the window all the way down, push the rubber strip down till its about flush with the edge of the mirror and put a bit of graphite power on the window runner in that rubber piece to stop it form grabbing when the window is wound up.... put the mirror back on and wind the window up to see if it fixed the probelm
