just picked this up this evening. VN exec V6 s1 with T5 box. it's lowered on what looks like super lows. unforunatly it's a wreck cause it was lost backwards/sideways into a power pole. ok for $700 i guess.
this is the start of the project. now i have an engine and driveline to go into a nice and light VK maybe. if i can find a decent ecotec then i'll bolt the trans to that instead. it's got an LSD to put it single pegged when i gave it some stick
for all those NZ members in the auckland area, if there are parts your after PM me. most bits avail except the engine/driveline/ecu & loom etc. there is also a clubsport front bar on it that i'll be happy to sell
Body by Holden, Soul by Brock
the Legend will live forever
sounds good immortality, I've always been a fan of vh-vk's. I've owned 3 VK's and 1 VH and i like my vp but i love the vh-vk body shape. Last couple of months i've been thinking of getting another one and putting a v6 in it. Are you going to do a s2 top end transfer should make it a bit better for a transplant into older model.
not sure i get what you mean unless your talking about making it more compatible with the cooling system setup? eventually i'd like to go to a ecotec but geting it running with the buick will be the first goal. need to find a good VK body first now. preferably a four banger, that way i know the chassis hasn't been stressed to much.
unfortunatly the missus isn't to happy about me having a wreck sitting in the driveway. there is another 1990 VN 5 speed that i cna get my hands on for another $600 but i don't think that will fly with her. maybe i strip this one fast for the bits i want and dump the body, then, sell some bits to get some cash together for the other one, that way i have at least on spare T5 box to play with. the previous owner said it has a brand new clutch and a recently fitted new power steering pump so that's all sweet
yeah cooling system was what i was talking about. Did you get many 85 model vk there? i was thinking that one would be better for the bw diff.
a few, would like a VK1/2 if possible. thought i'd end up using a VL diff so that i can have 28 spline shafts and maybe run a minispool, cheap, easy to install and fun![]()
not sure whats been done to the motor but i just pulled the memcal out and it's definitly been tuned for something? the sticker has V6 + 6 written on it. not sure what it means. will have to get my willem burner working so that i can read it. i'm currently having a software conflict with the Eprom51 software that came with it. it loads ok, but as soon as i go to diagnose harware the program crashes. the burner plugs in a the diodes work etc. the software crashes wether or not the burner is plugged in so i'm sure it's a software issue. thinking i might have to re-install XP to get it working as i'm having a few other software issues also.
going to get some degreaser on the weekend and give the engine a good clean so i can see whats been touched. i may lift a rocker cover off and put a dial gauge on the lifter to see if the cam has been changed
just pulled the intake and pod filter off. it has a 65mm V8 TB fitted thats already been modified to make sure it opens 100% although instead of altering the cast stop on the TB they have modified the steel bracket instead. someone has definitly done some work on this .....
hehe that red thing?, hehe i really want to drop a T5 in mine
I cant tell you for a fact a Buick 6 into a VH rocks. Theres a guy who used to come on our cruises in Victoria who had a old rusty VH wagon, we thought nothing of it. Till he came flying up our arses one night, opened the bonet and there was a VN v6. From what you also say there has been some work done so putting it into a light shell will definalty go a treat.
Whats with the gay bonet scoop looking thing haha? The paintwork looks mint, shame its totalled. Good find for under a grand, you could resell the manaul conversion for more than that. Good find.
Grennan is this the one? i remember it was a brown wagon.
Holden Commodore VH Vacationer Wagon - eBay Commodore, Holden, Cars, Cars, Bikes, Boats. (end time 16-Nov-07 14:26:46 AEDST)
pulled the TB off this arvo, where ever they got it from it was marked as S.V. so i can assume it came from an SV model. pitty, thats one less SV on the roads.
had a quick go with a dial guage this arvo also but battling against hydraulic lifters it was a total waste of time. will have to remove a rocker and measure lobe lift to see what cam is fitted.
what ever they have done it definitly sounds good for a V6, at the mo it only has a single muffler with the pipe dumped after the diff (had to remove rear muffler after the boot was crushed - exhaust mount was damaged). it's a 2.5" system but with the factory tubular exhaust type manifolds
