Results 1 to 10 of 10
Thread: vn runs good for 20mins then starts cutting out?
    vn v6 wagon
    Nov 2007
    Default vn runs good for 20mins then starts cutting out?
    my vn wagon drives spot on for 20 minutes and then starts cutting out both driving and at idle just put in new fuel pump fuel pressure reg and harmonic balance any ideas please
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Something to do with closed and open circuit? Have you checked for any error codes by doing the diagnostic test?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Possibly the DFI module.
    I had the same problems about a month and a half ago. Replaced heaps of stuff, turned out to be the module itself.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    vn v6 wagon
    Nov 2007
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    tried the CAS yet? most common problems i've noticed where it starts fine cold but when hot fails to start or dies usually comes down to the CAS
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by Bz Kn33z View Post
    Fuel filter, check the lines, could be alot of things
    Very true, could be leads, plugs, coils, ECU, wiring loom for ECU plus a million and one other things.
    missus (in more ways than one)
    Sep 2005
    next time it cuts out, make sure your carrying a bottle of water, pour it behind the biggest pully on the motor (harmonic balancer) then if it starts strait away it's your crank angle sensor
    vn v6 wagon
    Nov 2007
    it is the cas have taken the harmomic balancer any ideas on how to get the studs off the sensor cover cant get them given me the ****s
  1. VP only starts on second try
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2006, 11:51 PM
  2. Car starts in on position
    By Cal.oz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2006, 09:50 PM
  3. Runs Good Runs Slugish ??????
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2006, 04:01 PM
  4. heat problem - runs fine, starts to misfire then dies
    By mgvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-09-2005, 11:01 AM
