1stly, you dont need 2 threads about the same thread.
2ndly, if you have no idea about prepping, which is the most important thing bar runs and overspary, practise on something else.
Basically, it needs stripping, then sanding, body filler, sand, bog, sand, maybe more bog, sand, (body should now be dead straight) primer.
AFAIK, you dont sand primers as the point is to provide a surface to stick too.
You dont put clear coat on 2pak white as it will turn cream....
aZk.
LinkBack URL
About LinkBacks
