Results 1 to 4 of 4
Thread: vn and vr level3 dash
    VN Phoenix Red Berlina Wagon
    Apr 2007
    Kendall NSW
    Default vn and vr level3 dash
    my lvl3 vn dash is up to sh*t. It shows there to be more fuel in the tank then there actually is, and the speedo acts erratic sometimes and often is on the wrong speed. So I purchased a lvl 3 dash from ebay thinking it was a vp dash as stated. Im rather sure it isn't because it says VR and 1993 so im pretty sure it is a VR lvl3 dash (GM part number: 92042475).
    I know you cant put a vr dash into a vn so... what can i do to make the vr dash usable in the VN? do I replace the flexible circuit thing? or what?
    Or alternatively do I swap the little chip things inside the dashes (i think it is called a voltage regulator or something) and hope that fixes my original dash?
    I hope you can understand my long post, and look forward to any replies.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    It's possible that you could find unbroken bits in the VR dash and swap them into the VN dash... but I'd be more likely to ask the seller for a return + refund, and leave him some bad rep if he disagrees. Most ebayers turn around at the idea of bad rep
    Other than that, perhaps try and sell the whole days in our for sale section (or even on ebay) to make your money back, and then use that money to buy an actual VN/P cluster
    The 1972 HQ Kingswood
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Is the flexible circuitry stuff on the back the same colour on both clusters mate? Or are they different?
    Apr 2007
    Kendall NSW
    They are both green.
    All of the numbers on the back for each connector are all different so I guess I will just sell the VR one unless there is still a way to do it.
  1. VR/VS Level2 to Level3 Dash Cluster Upgrade
    By wheredoesthisgo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2007, 05:00 PM
  2. Level3 Cluster Fitting for VS SII
    By VTS5 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2006, 12:07 PM
  3. Replies: 2
    Last Post: 02-11-2005, 07:10 AM
  4. Changing a VP standard dash to a Tacho Dash
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 01-07-2005, 11:35 AM
  5. Custom Dash + Coloured Dash Lights?
    By ViperVp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2005, 09:08 PM
