my driver side power window goes down but now it wont go back up can anyone help!! plz
try keep pressing the button over and over again that miighy help u...press to go up..
VR EXECUTIVE
We had some good times
try gripping it with pliers and a bit of rubber and pull up as you press the button.
pull the button reverse the wires and try that (pushing to go down but window should come up) This will let you know if it is the switch.
mine had the same problem, i took the switch out sprayed some rp7 or some inox on the back of it an now works perfect, dust an crap all builds up on the wires
