Results 1 to 19 of 19
Thread: rebuilding buick 3800, what sort of things should i consider???
    Nov 2005
    Default rebuilding buick 3800, what sort of things should i consider???
    looking at rebuilding my vn v6 as i wanna throw some boost into her, what sort of things should i be replacing and with what so ive got a strongish motor, dont wanna spend too much
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Well that kinda depends on how much boost you want to cram in there How many kays do you have on the engine + how many PSI do you want to push?
    But to give you an idea, people have generally run up to 10psi safely without opening up a buick 6 - given that the engine has around 200,000km on it, and runs nicely.
    The 1972 HQ Kingswood
    Nov 2005
    yeah but i see those ppl killing there motors in 3 months too, what is it that dies on them? pistons slamming into bores?? rods?
    Jun 2005
    mines been running boost for a year now. still going fine
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    cruzncommo is offline Banned
    VP 5spd
    Nov 2006
    QLD
    buick grand national conrods/pistons, custom grind cam, work too block, stroke to 4.2L, lots of headwork, better valve setup, bigger tp and port matched manifold, double row timing chain, aftermarket computer.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    bah,
    ok ill tell you...
    what kills motors with boost
    pre-ignition
    detonation
    pinging..
    geuss what... its the same thing... the BIGGEST killer of motors with boost is detonation, most people dont change injectors or tune, leading to MASSIVE detonation blowing out headgaskets, shagging bearings etc..
    you can run upto 14psi on a stocker 200,000km+ buick motor SOLONG as its running within 10-12 afr on boost,
    what happens with detonation is the bearings get slapped round and end up spinning
    when i turbocharged my ol v6 i had a issue, the timing was broken due to the balancer being off key.. this meant i had +10 deg spark all the time (same as a dissy cap) this destroyed the motor see pictures...
    the damage:
    cracked heads
    crap on pistons like melted on
    2 spun big end bearings, 1 spun main bearing. all bearings shagged
    timing chain tensioner snapped.. probbly lots more damage i just didnt find it
    what i can reccomend is, get a good running motor, and boost that,
    solong as you dont go over 14psi you shouldnt throw a rod or brake any pistons
    personally id run 12psi max
    i blew a headgasket then ran ACL race series ($120 a pair) the motor broke before these.. heh
    weak points of the motor:
    bearings
    seals letting go
    pistons & rods only rated to 14psi
    valve springs are spongy and will limit power over 3000-3500rpm
    valve stem seals are usually gone
    inlet gaskets usually leaking water into engine
    strong points
    crank can take alot of punishing
    heads are strong
    faily easy to tune
    please listen to my advice, ive spent a year of playing, braking, learning and experimenting, not just some newbie jumping on here saying do this this this.. i got vp lukes engine which went thru a year of being supercharged, then turbo charged, and when i got it, it ran perfect up untill the day my mum wrote the car off :P
    that motor was bog stock except stronger valve springs
    soo yeah strong motors solong as they're tuned!
    Nov 2005
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    glad my shagged engine could help someone out
    your most likely to shag a bearing than throw a rod, remember to always check boost levels via a gauge soo you dont over boost.. also oil pressure is essential, id reccomend getting a gauge
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    You could also look up the Formula holden engines they were some big reeving motors.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    but they are built for N/A and run a higher comp ratio and not suited to boost
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Go without boost be the only Buick running over 8000rpm.
    Take more on the bottom end but you should be able to pinch some ideas from it at least.
    LowVp's Avatar
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    N/A hp has more wear and tear then a engine under boost just due to the revs
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I'll take boost.
    vs commodore executive
    Aug 2007
    Quote Originally Posted by PaRaDoX616 View Post
    bah,
    ok ill tell you...
    pre-ignition
    detonation
    pinging..
    the damage:
    cracked heads
    bearings
    seals letting go
    strong points
    heads are strong
    faily easy to tune
    those crank bearings look like mine sorta sep mine wasnt under boost just previous owner stuft it buy doing head gasket and water and oil mixing and driving it like that
  15. #15
    vn calais, vs clubsport #137
    Jun 2005
  16. #16
    VP Commodore Exec 3.8
    Aug 2011
    Wagin W.A.
    smaller 2/3 and 5th cyl oil ports are much smaller in the block than the rest, chappy in the states drilles em out to 5/16 or even 3/8 with no pressure drop as i have done during rebuild, google Jack Merkel in the states, has some rather warm mod options there!!!
  17. #17
    Aug 2011
    Wagin W.A.
    i have stock rods and slugs from a vp in my baby/warm VR, as block was std too
  18. #18
    Aug 2011
    Wagin W.A.
    also timing cover will let oil water mix if corroded too much and doesnt do the oil pump any favours either
  19. #19
    ClairBear's Avatar
    ClairBear is offline Make the stupid stop!
    VE Omega / Hyundai Getz
    Nov 2003
    SA - The Murder State
    Tappet: I would love to tap you on the head hard for digging up an old thread.
    Quote Originally Posted by commodore1310 View Post
    Ok, once again ive run aground with a bunch of elitist PRATS who think they know it all, stuff your cars and stuff your forum!
    Quote Originally Posted by one_and_only2004 View Post
    No, driving a v6 engages GOD MODE. Please don't continue the argument...
  1. rebuilding me v6
    By stockvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2007, 11:40 AM
  2. rebuilding 5.0L
    By bundyman in forum V8 Development and Modification
    Last Post: 11-08-2006, 10:44 AM
  3. Rebuilding Vn 5.0
    By griffindore in forum V8 Development and Modification
    Last Post: 21-04-2006, 12:14 AM
  4. Rebuilding Vn V6
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2005, 09:35 PM
