Results 1 to 4 of 4
Thread: oil warning lamp on and headlights on when braking
    vp executive
    Nov 2007
    Default oil warning lamp on and headlights on when braking
    hi just wondering if anyone can help
    I have a vp 1992 and i have to take in for a road worthy today yesterday we changed the oil and filter and my other half put 5liters instead of 4.1 in there was no probs until we took it to get an engine clean once finished oil waring light came on and wont go off so i got him to take out some oil he removed about 1 litre waring light still on.Also after the engine wash headlamps come on at braking only showing parkers just wondering if any one has any ideas
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Check to see if the electrical connection of the oil light is still plugged in, its above the oil filter on the engine block and its in a vertical position, can't miss it.
    Did you recently change some of your brake globes?
    Illegitimi Non Carborundum
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by resedent View Post
    So, from what I gather from this unpunctual sentence is that you had nothing wrong then you took it somewhere to get an engine clean, inside or out? Then when you picked it up you have electrical faults, seems to be the problem of the shop who did the clean...
    vp executive
    Nov 2007
    Thanks for your help. It looks like the electrical connection was a little bit loose or had moved a little, so a little fiddle and it was fixed. The lights on the other hand was the wrong globe, once I had a bit more time problems fixed. Thanks once again sorry about the bad sentence before was in a bit of a rush.
  1. SRS warning Lamp fault????
    By zammo05 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-11-2008, 09:23 PM
  2. Airbag Warning Lamp
    By VT_Boi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2007, 08:34 PM
  3. warning lamp check relay
    By Old fart in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2007, 07:30 PM
  4. LED in Calais warning lamp display
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-10-2006, 01:59 PM
  5. Tail/brake Lights Warning Lamp
    By Frederick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2004, 07:19 PM
