Results 1 to 4 of 4
Thread: removing vn berlina seats
    Nov 2006
    Default removing vn berlina seats
    hey just a quick 1 can any1 explain how to remove vn seats?
    thanks Ben
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    There are four allen key bolts on each front seat. You'll see one in each corner, just undo those and the seats will lift out.
    Rear seat I think you have to lift up the bottom and pull out. Just have a fiddle with it, its not too hard.
    BA XR6T, VG S Pack
    Jan 2006
    SA
    The upright half of the back seats, has two bolts holding it to the floor, undo them, then lift it upwards, as it has hooks holding it on.
    VN Executive
    Apr 2007
    Wellington, New Zealand
    i just removed a seat from a vn wagon took an hour due to the way the bloody things are secured.
    1. slide seat far back undo the 2 front hex bolts
    2. slide seat far forward undo the 2 rear hex bolts
    3. on under side of rails are 4 bolts undo them and the seat comes off.
    you may have to move the rails forwards and backwards to get to the underside bolts
    note: the bolts are self-tapping and lock-tighted in, it takes a lot a effort to get them undone from my experience.
  1. removing front seats
    By Co0kiE MoB$tA in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-03-2010, 05:30 PM
  2. removing vk front seats
    By dijm8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-04-2007, 11:03 AM
  3. removing vk front seats
    By Vk-5ltr Berlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-01-2007, 06:52 PM
  4. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
  5. removing rear seats VN
    By bido1 in forum Car Audio
    Last Post: 13-03-2006, 10:37 AM
