Results 1 to 24 of 24
Thread: thicker oil
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Default thicker oil
    Hey guys. i have some noise coming from under rocker covers somewhere, and i read somewhere that putting i thicker oil in might help. At the moment im using castrol magnetec oil which is 10w40. What oil would you recommend. I seen castrol gtx3 is 15w40, would that be good? or should i go even thicker? cheers
    Australia. Love it or leave it
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Usually depends of how tight your engine is and how many kays its done and how many leaks you have. I would say 10 40 is way too thin for your car, hence your valve noise, next service stick some 20w-40 or 20w-50 in there and see if she quiets down.
    iRiot's Avatar
    iRiot is offline Donating Member
    1993 S2 V6 VP Berlina
    Jan 2006
    Red Cliffs
    you should be using at least 20W50
    1994 Holden VR Acclaim Ecotec V6
    1992 Holden VP Berlina S2 retro fitted with VS Acclaim Interior
    Apr 2006
    canberra
    k cheers guys. i will go out and buy some now
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, I wouldn't reccommend Magnatec or any thin synthetic oils for a VN/VP engine. Stick with a good 20w50 Penrite oil for around $25.
    The 1972 HQ Kingswood
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Just had a look at the penrite site.. it recommends "HPR 15" which is 15W-60 for VN-VR V6
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by azzfox View Post
    Yeah, but as he said he can hear noise from his rockers, so im thinking he needs at least a 20w.
    iRiot's Avatar
    Jan 2006
    Red Cliffs
    if you use to thin it will stuff you rockers and your vavles will start sticking
    VT Berlina & mazda 2 DE
    Jul 2006
    OK guys
    15w will have nothing to do with lifter noise. 15w is only a rating at COLD. very cold. if you want thicker you have to look at the second number. 15w60 is far thicker than 20w40. even 10w60 is far thicker, as the second number is the relative rating.
    Lifter noise is caused predominantly by lack of oil pressure, due to wear or carbon/ sludge deposits. Thicker oil will help. Best look at some thicker oil which has good detergent properties as well. If you are finding more lifter noise say 3-5000 k's after an oil change your lubricant is failing.
    Apr 2006
    canberra
    just put some 20w50 in. still makes the noise. dont no if its lifters or what. its hard to explain what kind of noise its making. if the car is in neutral and i rev it constantly at about 2000rmp, you can hear it pretty loud, if its reving any more or any less it sounds normal. And when im driving around in say 4th gear at 60, and get to a hill, it does it then when under load. i dont know what the prob is. might just take time for my new oil to work
    iRiot's Avatar
    Jan 2006
    Red Cliffs
    it could be sticky vavles or anything
    sorry i cant help
    Apr 2006
    canberra
    its done it since i got my car, 2.5 years. But might have got bit worse. But car still runs really good.
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    most old motors make some noise lol its nothing to worry about if its done it for a while n still runs good. if it makes a tapping noise because of big ends or somthing it wont last long haha!
    13.3 1/4 exhaust only untuned!
    vn executives
    Sep 2005
    Quote Originally Posted by Morton View Post
    I used penrite gas and Gas10 for a while, they are great, gas 10 is a bit thin. just got a new car and want to sell the VN, do not want to spend too much on the oil so put Shell 20w-50 in, drove for 1500k, that is a ****, the engine is very loud and rough. before the penrite gas which is 20w-60 served the old lady pretty well. just a word of advice, do not save money on the oil, does not wortht the 10 or 15 bucks.
  15. #15
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    i use HPR 15 penrite in the vp with 187000 on the clock. work well from what i can tell
  16. #16
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    My brothers using that in his BA I6 sounds like a 500,000km VN
    I'm using a 15-40 in the VP right now little noisy at lower revs but runs a treat,
    Using 10-40 in the VT no noise what so ever.
    It's common in the older Buicks to get some hydraulic lifter noise, My old VP does it it can be as warm running temp, Stop the car and it will tap then at times it will tick or ping it's one of them not to loud but i can hear it outside standing, But power is there it runs right still, That might be the problem?
    Chuck some of that additive that stops lifter noise?.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  17. #17
    Morton's Avatar
    May 2006
    Quote Originally Posted by andyli View Post
    And good advice it is. Never a truer word spoken.
  18. #18
    Jul 2006
  19. #19
    crazywog's Avatar
    crazywog is offline VS V6 ECOTEC KING
    my fully shick holden bro
    Oct 2006
    In my fully shik holden bro
    yeh i agree there 20-50 works well with any engine. i also heard shell helix is the best for holdens anything else is just garbage.
    RAJAB RACING
    FullBOOST
    PRESTON AUTOMATICS & DIFFERENTIALS
    etstreet.com
  20. #20
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by bradcad View Post
    SLICK- Either that or a thicker oil with good detergent qualities
    Thats right i remember you talking about that and helping removed contaminants from the motor which might be helpful to coolvn.
  21. #21
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    Quote Originally Posted by crazywog View Post
    take out the sponsor list in your nickname loll you dont no any of those people,
    from nick @ preston automatics
  22. #22
    Keesh's Avatar
    Jan 2006
    any commodore over 200,000 needs 20w 50 any main brand is fine as long as your using the same brand consistantly
  23. #23
    Jul 2006
    Quote Originally Posted by Keesh View Post
    good point- i agree to find one that works for you and stick with it
  24. #24
    vn executives
    Sep 2005
    also it might be that you used synthentic for a while and then changed to mineral and this will make some problems. I will change it back to semi later.
