Ok i have a Vn Wagon That im fixing for my sister The Fuel pump Was playing up and Simtimes you Had to Give it a Light Thump to get it started ... Ok So i pulled That Pump out And Replaced it with a New Pump and Still no priming at The Pump so i pulled That One out and tested it with a 12 volt Battery spun up fine so then Put it back in again and still no go .... ?????
Also have Checked the Fuses & All The Relays Ect
Pulled The fuel pump Power connector off the rear off The Pump and Checked if its getting Power with a Multi Meter Reading Was in 11's so she has Power The There..
do you think The Earth Wire on the Fuel Sender is Faulty Or Something ?
Any Help Would be Nice Cheers!
