Results 1 to 4 of 4
Thread: Timing cover
    Vn
    Nov 2007
    Default Timing cover
    Hi
    i have just removed the timing cover from a commodore vn , to swap it over from my wreck , i had to remove the harmonic balencer to do this , now everything is all back together , the car is vibrating alot , and there is a sort of tapping sound , im thinking the harmonic balencer is causing this , any help would be good '
    Thank you
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Vn
    Nov 2007
    you mean the timing chain, ??? the thing is , i didnt touch the timing chain,
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Oh....I must of misread, I thought you changed chains...Hmmm, Crank angle sensor was disrupted or damaged in the process?
  1. vn series1 timing cover help pls!!!
    By piniin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-11-2007, 02:21 PM
  2. Timing Cover issue.
    By fitzy2005 in forum General
    Last Post: 02-09-2007, 07:47 PM
  3. timing cover...oil pump
    By Meerkat in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2006, 10:41 PM
  4. timing cover
    By callum87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2006, 07:52 PM
  5. timing cover
    By dave671 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:09 PM
