Results 1 to 17 of 17
Thread: rebuilt 5ltr
    car
    Jul 2006
    greensy, melb
    Default rebuilt 5ltr
    hey all,
    if a 5ltr has been rebuilt is there any way of telling it has if there is no receits?
    "A life lived in fear is a life half lived"
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Dots of paint on bolts? ummm, take it for a compression test? Dyno run should tell you how much power she has, the fresher it is the more power it will pull. These are all just guesses, i have no idea how to tell. Take the oil cap off and have a look at valve springs etc, see if they look new?
    VP Exec,Gsx-R 750
    Mar 2005
    Quote Originally Posted by odyssey View Post
    hey all,
    How long ago was it rebuilt? If not long ago, it should be quite clean, if they were smart it would have new hoses, and new engine mounts etc. The engine has to come out to be rebuilt, so look for signs it has been removed.
    Also look around areas where gaskets stick out for Ultra Blue, that sort of stuff.
    I once looked to buy a VL Turbo, the bloke told me it hadn't had any engine work that he knew of - all standard - I pops the bonnet, and every gasket surface had Ultra Blue on it. Dodgy rebuild perhaps?
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    japanese built motors dont use many rubber gaskets.... silicone sealant is pretty much all that is used
    VP Exec,Gsx-R 750
    Mar 2005
    Quote Originally Posted by Peanuts Inc. View Post
    Fair enough, but the point I was making was that the guy said no engine work had been done, roll the bonnet up, and the Ultra Blue made it quite obvious there had been.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Boonz's Avatar
    Jul 2005
    sorry lol...new welsch plugs should of been fitted??? they are easily spotted... no rear main seal leak
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I agree with this one, check for oil leaks for starters and the welsh plugs.
    car
    Jul 2006
    greensy, melb
    he said it has done 90,000km since rebuild, i was thinking welsh plugs but i havent had a 5ltr for a while now so forget where exactly they are.
    also new welsh plugs are usually goldy colour yeh?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    I'd probably pay less then. It's an old engine with (probably) 1 less re-bore left on it. After 90,000 km it can still be relatively fresh or just about ready for another re-build and anywhere in-between.
    Reaper
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    90,000km, well the engine hasn't been recently rebuilt in distance wise, it's a fair run in. Not saying there is a problem with 90,000km the engine is only a baby, but I wouldn't call it a refreshly rebuilt engine. If it had done under 40,000km or even less then I would say refreshly rebuilt. So I wouldn't give the motor credit.
    Yours Kindly,
    Jim
    Brucefromruse is offline CRAVEN MOORHEAD
    VS executive s2
    Oct 2007
    Campbelltown nsw
    Recent re-build .....well if i was gonna do that at least i would keep all my reciepts and maybe a few pic'c just to convince a potential buyer..i think someones fibbin...good luck.
  15. #15
    car
    Jul 2006
    greensy, melb
    i havent seen it yet i was just wanting to know for when i do see it cos ya never know they could just be borrowing the reciepts from a mate and saying its a rebuild thats why i wanted to go knowing what to look for.
    thanks for the input, 90,000km really is not that much.
    ya reckon i would have any dramas with it? the old 5ltr is really a strong motor and they go on forever
  16. #16
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    keep fresh oil in them and they're fine, if its been rebuilt the block will have been acid dipped, same with heads, 90,000km is nothing.. check under engine if its clean etc, remove only thing really u can do is rip the inlet manifold off and take a peak OR, take a rocker cover off and try n peak, gunk build up etc
    COMP TEST IS NO WAY TO FIND OUT IF ITS BEEN REBUILT!!!!
    carbon can raise the compression and if you loose comp you WILL know about it
  17. #17
    vn 5 litre
    Nov 2007
    compression test will tell you how new the rings are and if they have done them most otherthings will be done
  1. Rebuilt T5 out of V6
    By ChargedAuto in forum Parts And Other Items For Sale
    Last Post: 16-11-2007, 01:59 PM
  2. rebuilt 3.3
    By figjamidhVK8t4 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-03-2007, 07:57 PM
  3. Where can i get a 202 rebuilt?
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-12-2006, 10:43 AM
  4. rebuilt LSD
    By Boonz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2006, 09:15 PM
