Results 1 to 3 of 3
Thread: CAS and Balancer Swap
    VX S2 S-Pac
    Oct 2005
    Default CAS and Balancer Swap
    Hi, heres the story, i have a VP commodore but i swapped the motor in it with a VNS2 motor.
    Now the CAS went bust and when i went to change it i realised that between VN and VP the change in the balancer must of come about so the CAS from the VP motor has a much large gap between the 'bits'.
    what i am wanting to know is if it is possible to whack on the VP (larger) sensor and also the harmonic balancer that goes with it....will this work, and im asking first bcos taking the balancer off again isnt the most exciting thing to do
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    the vp balancer and CAS have to be used together to work without clearance issues
    VX S2 S-Pac
    Oct 2005
    yer i ended up just trying, i thort i may have had issues with having a VP balancer on the VN motor cos the slightly different weight etc. but all good it runs fine now n no more misfire from my old dodgy CAS
    And i sure do know about mixing a CAS with a diff balancer as i smashed up a VN CAS once and they are about $98 for a new one from holden!!, just for that small sensor..
  1. Harmonic Balancer
    By partegirl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2007, 02:26 PM
  2. Replies: 2
    Last Post: 27-09-2006, 11:29 PM
  3. Harmonic balancer
    By BLUE_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2005, 06:15 PM
