Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By PaRaDoX
Thread: V6 valley cover gasket
    VN S - VR Statesman - VX Executive
    Jun 2005
    Default V6 valley cover gasket
    What is involved in changing the valley cover gasket ?
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    you mean the inlet valley gasket?
    ive done a few before,
    its simple unbolt inlet manifold, fuel lines etc (drain coolant first otherwise you'll get coolant in your oil + cyclinders and make u think u made headgasket gooooo when u havnt)
    undo the small black bolts round the outside (be sure to use a imperial socket not metric or u'll round them, its easy to think its a 10mm but its not)
    and pull off alternator + engine belt to get to some bolts and throttle plate has to come off too, then remove it and swap the gaskets
    DONT USE THE ACL GASKET KITS, they're crap the blue gaskets split way too easy, you have to do inlet gaskets aswell as they only sell them as a set, but its worth it.. they're all shagged and leaking water into the engine sucking your powa
    find the black flat inlet valley gasket seals they're tops never break (Y)
    from memory the kits are $40-50 and it takes 1 hour to change them, its pretty damn easy if u ask me after doing it heaps
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah they're crap (usually acl gaskets are aight) the actual gasket between the head and the inlet manifold is good but the valley seals that seal the block and inlet manifold (little rubber bits) split down the middle and fall out EASY, best to get the ones that look like stockers (nice n thick middle bits)
    Jul 2006
    Ahh crap, i already bought it....$80 for the kit for a vx ecotec.. The gaskets look pretty thick. Are you saying the blue bits split on the main gasket, or you taking about the red end seal pices. For my car, it came with 4 end pieces, but the manuals show 2. Maybe they have em in 2 pieces. How do they fall out once you have used the blue loctite on them ? Dont they like fit into a groove ?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    VN Wagon
    Feb 2005
    I need to change some lifters soon so the inlet manifold needs to come out, can you write up a bit of "how to" and maybe take a few pictures?
    Jul 2006
    Yeah, i will do so, either on here, or on the sister forum.......there already is one for the buick engine on another forum, let me go find it............but yeah, im thinking if i should do the lifters or not...........they are slightly noisy but then again its normal for these motors and ive read on other forums where after a few months the new ones just get noisy again.....plus if you put the wrong ones in, too hard etc they run the risk of damaging the cam.........did you try some lifter cleaner /???
    Jul 2006
    VN Wagon
    Feb 2005
    Quote Originally Posted by vxcalais_01 View Post
    http://forum.****************.com.au...anifold+gasket
    Thats the link.......i will do one similar on here for my vehicle.
    Link censored for some reason.
    Yes I have tried both lifter free and engine flush.
    Jul 2006
    Jul 2006
    VN Wagon
    Feb 2005
    Jul 2006
    THey obviously dont want links or advertising to other sites. Which is fair enough.
  15. #15
    99 VT Series 1 Wagon
    Nov 2010
    Got quoted $250 to have this done today,
    Seemed a bit steep. To me ..?
  1. Is it hard to change my valley cover and rocket cover gaskets
    By eagle13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2010, 09:39 PM
  2. Valley cover gasket
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2006, 03:55 PM
  3. rocker cover gasket
    By jim898 in forum V8 Development and Modification
    Last Post: 10-01-2006, 12:36 AM
  4. rear main seal, left engine mount,valley cover gasket,minor service $900is that good
    Last Post: 12-12-2005, 10:31 PM
  5. Wanted Valley cover for Vp 5l
    By jamo25 in forum Swap / Wanted to Buy / Trade
    Last Post: 29-11-2005, 01:18 AM
