has any one put a 5.7ltr say vx vy or a vz into a vn ?? if so what is needed??![]()
One hell of a lot, apart from the obvious (engine, trans) you would need computer, diff, suspension. Basically take the guts from a VZ for example, and fit it to a VN shell.
Originally Posted by wikky
Plus what he said ^^^^
i can get motor an box for 3k but whats needed to be done to the vn like cuttin welding **** like that from 1 nut to the whole thing
Some guy in NZ did it, full conversion, cost around 10-11g all up. Just buy a VY wreck and do the transplant. Not easy, but anything's possible with the right amount of time, money and patience![]()
i seen a guy at the drags yesterday with it done but didn think to ask him
what about a 350 chev what is needed???
needs custom made block mounts to match the K frame... ive seen one in a VR maloo, but stroking a holden motor is easier....
we have a VB wagon with factory fitted chev, has different chassis rails and runs a steering box that hangs through the inner gaurd, custom K frame and custom sump & pickup.... most of this is to get around the holden steering rack which gets in the way of the chev starter motor,
you can buy kits that space the k frame but your car will never be low and its a horrible way to do it (guy in our car club has it done like this... looks ****e)
Japanese scientists have created a camera with such speed that they now can photograph a woman with her mouth shut!
ok kool what about a vs ss motor i dont want to sell my car??
Yeah a 5L is relatively easy.
Engine, Box, K Frame, Radiator, Trans Cooler, ECU, Front Springs and you're basically done.
Its a much more common conversion so there is alot more detailed information around and the parts are cheaper also.
yeah ofcorse a tv what are you guys talking aboutjust kidding typo.
13.3 1/4 exhaust only untuned!
so if ive found a whole ls1 vx spac and want to put it in a vn all i would really need is engine mounts? cos i can use everything else from the vx?
"A life lived in fear is a life half lived"
anyone managed to put a LS2 into a vn\vp or vr\vs yet? that would be a cool conversion
Engine mounts, trans mounts, remap of the ecu, custom power steering hoses and radiator hoses, custom headers, also you have all the wiring which will cost alot from an auto elec. Also, custom tail shaft I think.
Still several grand to spend after you find a donor car unless you fabricate everything yourself.
