Does Any One Know How To Fit Welch Plugs To My Vn Located Under Exhaust Manifold ! There Is Only One Leaking Do I Change Them All Any Info Would Be Great Im In The Dark With This One Help:
Mate Probably Easier Too Get Someone Else To Do It. Especially Typing Like THis.
pull the manifolds off, starter motor and do both sides cos usually if ones leaking, the rest arent too far behind
So How Do Iget The Welch Out & What To Do To Put Them Back In Any Spec Tricks![]()
lol you love capitals
the service manual says :
1) tap it into it's opening using a punch and hammer.
2) grasp the edge of the plug using multigrip pliers, then use shoulder of pliers to lever plug out
3) clean the hole
4) coat the new one in Loctite 242 or equiv
5) using a socket fitting the rim of the plug, or a suitable tube, drive the plug squarely into into the opening. Make sure it's square, or it will leak
Put it all back together, and bam, job done :P
Hope it's as easy as they make it sound
Cogez
Thank U Very Much Thats Helps Me Alot :no Info In Haynes Manual There R Useless :d
another thing is make sure they dont fall in the block
this is bad
if it taps inside the block, it could set off the knock sensor backin off the timing causing lower power.
WTB: mulberry VN interior parts
i will slap you
Try me, I'm 4000km away. Ha!
