hi,
was driving my car today and went to put my window up, it seems as though it has fallen off the mechanism in the door. How do i fix this? i havent touched the switch except to try and put it up as it happened.
thanks
dont keep trying to force it up, otherwise you'll do more damage.
Usually the little nylon sliders break and the window becomes dislodged. you need to remove the door trim and support the window with a block of wood etc.. and get some new nylon slider things (you'll see what i mean) from holden for a few bucks.
Power is measured in DECIBEL
