Results 1 to 11 of 11
Thread: how to remove both windscreens to fix rusts?
    NO CAR ATM.. -.-
    Jul 2006
    Default how to remove both windscreens to fix rusts?
    ive seen before taking the windscreen seal off theres like a tar looking thing attached from the window to the car do i just cut that along the window?? i duno wat to really do n i need help,
    when the windscreens are off and after i sand the surface rust down do i get rust converter to prevent future rust?? and what kinda body filler if it has holes?? andd when its all finished the glue to stick the windscreen back on.. is it sum kind of special glue ?
    nnn im gonna primer the roof after this is finished for a complete roof spray
    p.ss i h8 rusT
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The glass has to be cut out - the rubber strip is tuff stuff.
    Remove all scale and surface rust with wire brush - may take several hours to do.
    Treat all rust with some goo from a "body repair supply shop"
    Body plastic (same supply shop) is a 2 part mix to fill the holes.
    Sand smooth & paint. Put some masking tape (2") on the roof to protect the paint a bit.
    Get the windows put back in by someone with the sealer kits (I got complete windscreens to do it for me $150 or $160 from memory)
    I did a thread on this 6 months ago - may have been lost when JC's lost some data.
    and 3 Dangerous non ABS VN's
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    This is why im taking my car to a professional to get it done, I get the rust cut from front and rear windscreens, roof and pillars painted, etc. While im there ima get my front bar fixed and rear bar resprayed along with my rear wing, looking at about $1500.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Windscreens are taken out using strong wire....rubber trim pulls out from around glass showing the window and the urethane sealant attached between the glass and opening ....make a flaw through the urethane with a knife and thread wire (I used a fine guitar string) through hole made so one end is on the inside and the other is on the outside ...get a 2 bits of dowel and tie each end around the dowel place between fingers and with a second operator and move it back and forwards cutting all the way around the opening until you get back to the start make sure the action is moving wire in a u shape and not in a straight line as if you dont you will rip into the paint around the openning ...strange thing is most rust is formed by the so called experts dragging this wire over the painted surface and giving rust a place to start...they dont care the trim goes back on and you are none the wiser until you notice a bulge under the rubber trim.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    or you could pay a glass guy $50 to do it..... thats what i done.... all up removing the rush from both front and back window, cost me about $500, doing it myself.....
    Vr calais
    Sep 2007
    When they done mine they used a knife like a stanley knife with a long blade and cut from the inside pushing it flat against the glass and into the europhane sealant then cut around it came straight out then they give it a clean up and attached the rubber bit to the new screen went around the old sealant with new then stuck it back in and used the wedges at the bottom of the screen to get it into position and i had to leave it with the windows down so it didn,t pop out when i closed the doors for 8 hours but basically it is a polyurethane type sealant that holds it in amazing how strong that stuff is. i would persoanally mig weld any holes cut out rust and make new sections weld them in and most importantly after the repairs are done get in behind the repairs and use whatever rust converter primer etc and coat it well that is usually why they rust because there is no paint on the metal inside hard to get at areas
    VN Executive
    Apr 2007
    Wellington, New Zealand
    when you remove the rust make sure that the end result is a smooth bare metal surface, prime it then paint it with automotive paint.
    allow 2 days to dry otherwise the screen will just pop out.
    this what i was told when i had mine screen replaced and i had to clean up rust, the black glue stuff only sticks to paint.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    When I took my car in for a quote the bloke said that the rust around the top front windscreen was caused by a person removing the front windscreen and scratching the paint deep, this in turn caused corrosion/rust which formed under the rubber seal. Be aware of this.
    VN Ute
    Oct 2006
    yea my screen was taken out when it was painted before i got the ute - the ****ed up bigtime lol.... was real bad under there cos they scratched all the paint up - no worries as there was no holes just scabs forming
    its also good on pre-vns when you refit the windscreen to use a vn rubber to get rid of the plastic surrounds that double as water tanks
    Japanese scientists have created a camera with such speed that they now can photograph a woman with her mouth shut!
    NO CAR ATM.. -.-
    Jul 2006
    the rust aint that bad when i sanded it 2weeks ago it all came out no holes caused from rust anDD thanks everyone for your replys !!! helped so much hope it turns out to be all gooddd, since its getting painted to should i leave the windscreens to be last to put back on?
    vnss
    Jan 2005
    s.e melb
    yeah for sure cos primer absorbs water i fit dosent have paine on top so if you were to put the screens back in first you would cop the same **** again lol
LinkBacks (?)
  1. takin Windscreens off
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2007, 03:11 AM
  2. VN windscreens $30
    By churnit in forum Parts And Other Items For Sale
    Last Post: 24-03-2007, 02:18 PM
  3. should i remove IRS
    By fraesralj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2006, 06:29 AM
  4. rust around vl windscreens
    By hughey in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-05-2006, 11:18 AM
  5. windscreens
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-08-2005, 08:58 AM
