Results 1 to 14 of 14
Thread: vn heater tap bypassing?
    vn exec
    Sep 2006
    Default vn heater tap bypassing?
    ok on the drivers side is a stupid plastic piece i think is the heater tap
    is there a way to bypass this unit seing the bottom plastic peice has snapped off?
    car is a series 1 vn-any help ideas or importantly diagrams would be verry helpfull
    oh and before anyone says its all good get one from town ect rember i live 145km from the closest place to get one
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Gu8ys, can you please take a little more care when posting?
    The my ride section is for exactly that, details of your ride.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    vn exec
    Sep 2006
    minux's Avatar
    Feb 2005
    Quote Originally Posted by insane1 View Post
    sorry first time i needed to ask a question
    No probs
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yes you can just put a peice of straight pipe in place of it. Remember though it'll blow hot air the whole time its on the hot side.
    Also e-series falcons and vn-vr have the same tap if you want to grab a secondhandy
    vn exec
    Sep 2006
    this unit has 2 pipes from the back,one from the front and one from the bottom(the one thats snapped off(can you explain how a straight peice of pipe is fitted?)
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I've drawn up a diagram of the heater tap in my vp. The part you replace with the straight bit of pipe is where the water flows through.
    vn exec
    Sep 2006
    ok if thats the case what do i do with the other 2 hoses on the vn series 1?
    2 from back,1 from front+broken 1 at bottem
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    is the broken one a small thin hose that goes into the vacuum canister part (FIK what its called) ?
    Can you post up a pick? i dont have series 1 i didnt know they would be different
    vn exec
    Sep 2006
    lol-that makes 5 hoses then i was mainly interested in the water side of things+no i havent got a pic mobile phone died the other day(in reality i killed it)
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    hmm maybe someone with a series 1 might be able to help you. I dont think i know anyone with a series 1 sorry i cant be of anymore help
    VN Wagon
    Feb 2005
    If it is the small hose, then that is the vacuum hose. All you need to do is find the small vacuum hose and remove the broken plastic piece. Then block it up otherwise you will have a vacuum leak. The heater tap will either flow or not flow, I don't know which but it doesn't matter. You will either end up with warm air all the time or cold air all the time.
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    eaisest way to bypass teh heater tap is to disconnect it where it enteres the fire wall, and use some good old fashioned normal everyday garden hose and jam it down either end of the heater hoses, this creates a little loop, use a bit of tape to make sure it deosnt move, and go and get a new peice. either that, or remove the vacume redard line, youwill get cold air all the time, it closes the tap. preventing water to flow.
    i am the god of britany spears womanizer on just dance on the wii
    vn exec
    Sep 2006
    ok just for the ppl who are stuck in same boat the part was $40-but prob will be cheaper if you live in one of the major city`s
    genuine holden part
  1. air con/heater fan
    By Bunjey in forum Electrical Wiring / Questions
    Last Post: 06-03-2007, 10:17 AM
  2. park selector switch - bypassing
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-04-2006, 06:37 PM
  3. A/con Heater fan help
    By Maxie195 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2006, 08:29 PM
  4. heater tap
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2004, 04:43 PM
