Results 1 to 11 of 11
Thread: Air con / temp control not working
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Default Air con / temp control not working
    Hey guys, my control for the air con / heater etc doesn't seem to be working, when i go to change it from demister to say the vents or so the air comes out down at my feet, it doesn't change, it's coming out from the vents, down at my feet, the demister vents.
    Basically it has all the settings going at once, the loom in the back is plugged in properley and everything..........?
    I don't really wanna drive in the rain with no demisters.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    well i think a vaccum hose has came loose, with the plastic connector (the bastard to fit back on) in the back follow them down and make sure none of them are hanging.... thats what happened with mine
    sorry i cant give more details but i fixed mine ages ago :P
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Vacuum hose? As in those 2 flexible vent looking things that sit each side of the centre console sort of behind and to each side of the head unit? Forgive my ignorance lol.
    VN Calais 5L
    Dec 2006
    nah dude if ya take the dials out (like the whole thing, as if you were changing your headunit) you will see behind the dial that controls where you want the air to come out that there are small hoses going into the back of the dial (just above the loom i think). when your just driving around is there a sucking sound thats not normally there? if it is one of your vacuum hoses is either loose or not on at all.
    those flexible vents on the side send the air to the back of the center console.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Yep there sure is a sucking sound like air escaping from something.
    That's what i meant, that rubber plug is attached and so is the loom. Sorry i should have posted that better. It's got like coloured wires attached to a clear rubber plug that attaches to the back of the dial, then there is a loom under that.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Ok it's connected to the back of the control, but where does the other end connect to and is it hard to access??
    VN Calais 5L
    Dec 2006
    i couldnt tell you where its connected to at the other end. simply cos i dont know. lol. you havent broken a hose have you? or maybe put the vacuum hoses on upside down? (i managed to do it dont ask how). also the hoses dont have to be right off for it to suck loud. mine were on just not pushed right in as tight as they go when i had the sucking noise..
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Well i took it all apart and messed around and put it all back together and pushed that rubber plug on as far as it would go. Still no joy. Stuff it, it can stay broken.
    VN Calais 5L
    Dec 2006
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    It's been like that for about 4 months now. *turns bass up* easy fixed hahaha
  1. Temp gauge not working ??
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2007, 08:43 PM
  2. Temp Gauge NOT Working
    By VSStatesman in forum Electrical Wiring / Questions
    Last Post: 24-11-2006, 06:12 PM
  3. VS Statesman Temp Gauge NOT Working
    By VSStatesman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2006, 05:57 PM
  4. fuel and temp gauges not working?
    By MontieVHSL/E in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-10-2006, 03:32 PM
  5. Fuel & temp gauges not working!!!
    By nath_120 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2005, 11:33 AM
