You need to tell people what you have done to your engine as well.
A few comments which may or may not be relevant as I'm not familiar with Microtechs;
1. Idle is a bit fast.
2. AFR is rich at idle and across most of the log so I can only assume that it is 11:1 or richer. In other words if the AFR reading is valid you really need to tune your fuel.
3. At full load the AFR actually reduces slightly. You want to go richer at full load see #2.
4. Why does the load point jump from hg to psi? Makes it hard to work out what load site you are at.
5. MAP sensor may need calibration as you have a maximum reading of 19psi.
LinkBack URL
About LinkBacks
