On the weekend i had my bonnet up on the vp and the passenger side of it looked a bit lower than the other but i didn't think much of it at the time.
Then as i shut the bonnet i heard a massive "crunch" i look up and see that the back corner on passenger side hit the windscreen and cracked it now every time i close my bonnet it hits and make the crack bigger.
And when the bonnet is shut the passenger side sits up as if i have unlatched the bonnet.
I had a fiddle around with it but can see why its doing it, anybody got ideas?
Cheers steve
busted ass vp
try new bonnet hinges as my windscreen cracked because of that and i had to have a new windscreen and new bonnet hinges and new rubber for the windscreen do dont be suprised if you need new windscreen rubber as well as a windscreen and bonnet hinges
yea replace ya hinges or ya bonnets is loose off the hinges....
i had that problem once but the bolts holding the hinges in snapped and fell onto the window and crushed my fingers lol
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
lol i just replaced my windshield because of making a similar mistake, luckily insurance covered it.. again, already replaced it 6 months ago. otherwise is was going to cost $375NZD to get a new one fitted.
Ouch... man, that sucks! My right-hand bonnet hinges were coming loose at one stage. Caused the bonnet to be off-center and a bit skew. Hopefully it's simply a matter of realigning everything and tightening it up nicely... maybe some loctite in the bolts to help them grip?
The bastard is, the most expensive part will be getting a new windsreen >.<
The 1972 HQ Kingswood
It happens because if the hinges aren't lubricated regularly, they seize and bend, altering the swing of the bonnet when it's opened.
Yeah, this is true. I lube up all my hinges and joints every 6 months. It can also just be blatantly loose bolts which cause the whole assembly to slip.![]()
