Results 1 to 15 of 15
Thread: Anyone with a vn..
    VN Exec 89
    Oct 2007
    Default Anyone with a vn..
    Um on my vn under the bonnet i have no radiator cap anywhere, i cant find it?
    ive always kept decent engine coolant but on vps and vs's around the fan part is the radiator cap..mine doesnt have one? or if it does its hidden under this mass of plastic by the fan belt.
    Just seems really odd, ive owned a vc and the cap was in that exact spot too
    ill see if i can find a pic
    donza is offline donza
    VN S pack
    Sep 2007
    country vic
    VN Exec 89
    Oct 2007
    as u can see in this pic the radiator cap is clearly visible, mine isnt there and i cannot find it by tracing wires to it.do i have to take the plastic off by the fan?
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    VN Exec 89
    Oct 2007
    Nope 6, family friend whos a mechanic had a quick look and couldnt find it either LOL
    this means apart from services my car hasnt had new water in it for umm months? but yeah my bay is basicaly identical to that pic apart from the motor the CAI and also my engine coolant lid doesnt have those wires coming out connecting to something else its just a lid
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    VN SI V6 had a capless radiator... use the header tank on the drivers side strut tower
    Power is measured in DECIBEL
    VN Exec 89
    Oct 2007
    Ive only been filling the coolant tank on the left in that pic with water/coolant
    but i find it seriously odd that there is no separate radiator cap to fill just water into it?
    so basically all fluid like that just goes into my coolant tank as i have been doing?
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by kaziya098 View Post
    This is why I asked if it was a 6 or an 8. As stated, you fill it through the coolant tank.
    Selling FG G6E Turbo and buying a N/A Supra
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    i dont see why its such a problem, firstly your 'coolant tank' is different to the one you posted. you fill it up like your normal radiator, with the engine running and fill it right up and keep topping it up until the level stops dropping. most people change to the series 2 setup with the radiator cap once the original radiator gives way, but u need to change your header tank to the series 2 overflow bottle like the one in the pic you posted.
    VN Exec 89
    Oct 2007
    well my car didnt come with a manual, this is my first vn so i had no idea u had to do that but my tank doesnt overflow its just a tank u fill it goes nowhere that i can see. i just didnt understand it since everyone who owns a vn (but me) has a normal setup. Id love for someone to reply here and say they have a setup like that.
    if i can get a pic of my engine bay ill post it
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    yes, i and alot of other people have them... mine is a series one and it is perfectly "Normal".......
    vz wagon
    Aug 2006
    Wild west of Melb
    Take the cap off wile the engine is runnin and you will understand how it works and the coolent/water does go into the motor mate its the same on my vn.
    VN Executive
    Apr 2007
    Wellington, New Zealand
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    heheh you guys crack me up, the overflow tank is pressurized, it see lower hose runs into the inlet manifold, thats where it enteres the engine, top hose is return from the engine and the other hose going to the radiator is the radiator overflow.. now, what could be confusing about that? you'll notice the screw lid has a rubber seal in it to keep the pressure in....
    because its pressurised you dont want to open that when the cars warm... its baaaad mmkay fill it when the cars cold and fill it from there.. problem solved?
  15. #15
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Yep and then they had the inbetween setup like mine where they use another overflow bottle on the passengers strut tower. the header tank cap if fitted with a pressure valve and hose connection to the overflow bottle.
    If my radiator calls its quits i'll be getting a series 2 with a cap, getting rid of the drivers side tank and using the passengers side overflow bottle to be different
