hey there I have just bought a pair of King Superlows can i whack'em in with out changing the shocks or should I really change shocks at same time.?
cheers
SXCHSV
Is it IRS or not? What are the part numbers for the springs?
If the VQ is IRS it should be using KHRL-46SLHD springs which don't need shorter shockers in the rear and KHPR-22 or KHPR-22SL fronts which also do not need shorter shockers in the front.
If its non-IRS, they should be KHPR-20HD (superlow) or KHPR-20SL (ultralow) which require shorter shock absorbers to keep the springs trapped. All standard/non IRS rear springs in a VN/VP/VQ need shorter shocks to keep the springs trapped.
For the front, it should be ok. VR/VS onwards needed shorter front shocks for extended bump travel but the VN/VP springs did not. You should have springs with either part number KHPR-22 (V8) or KHPR-22SL (V6) or KHFL-22SSL (ultralow).
So if you have the right springs, you should need shorter shocks for the rear only.
Hey mate thanks for the Advice,
Yeah its IRS and as for the part numbers im not too sure of cause a mate of mine works at the local Tyre Place got them for me Cost price which is handy...
Also with superlows is it advisable to put a camber kit in the rear of the statesman.?
Looking forward to Dropping her down a tad....
cheers
sxchsv
Yeah i'd get a camber kit mate for sure, especially to stop tyre wear.
ALL VQs have irs.
Before you lower makesure your Rear IRS cradle isn't cracked.. Mine on the stato is... & it's getting worse...
It's a big problem in VQ statesmans...
MaT
Originally Posted by garth
Mmmm I got S2 shift kit, Corvette servo, Beast reaction shell, Kevlar bands & boost valve...
It shreaded the IRS cradle in under 2months....
i had superlows on my vq and didnt need to change shocks plus i didnt need a camber kit either, i dont know why but i had no trouble with rubbing or tyres wearing on the edges
"A life lived in fear is a life half lived"
