+ Reply to Thread
Results 1 to 11 of 11
Thread: Brake lights work in park but not in drive.....
    savage1987's Avatar
    savage1987 is offline fail champion savage1987 GTS savage1987 GTS
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Question Brake lights work in park but not in drive.....
    Yeah that pretty much said it all. What could cause this? I've no idea. Please tell me my computer is still ok lol
    They were working fine, only noticed this problem in the last week or so
    Sam
    WTB: mulberry VN interior parts
    Quote Originally Posted by levymetal
    hahaha
    you taste weird man
    WAIT
    WHAT THE SHIT
    your taste in music is weird****
    Quote Originally Posted by kikki
    she was imagining you naked
    chicks all do that
    1993 Series II VP Calais
    Sep 2006
    In case you've forgotten since last night:
    1) Check the brake light switch. Make sure it's not hangin out, and that all it's wiring is secure.
    2) Check if the brake lights work in neutral too. If they do, check the inhibitor switch and all it's wiring for a short. If they don't work in neutral, panic, rip out all the wiring, set fire to it, and replace it...
    Looking at the wiring diagram there really doesn't look like there's anything else that could be affecting the operation of the brake lights, and is their function is independent of the rest of the circuitry. It's just a simple switch that turns them on and off.
    iRiot's Avatar
    iRiot is offline Donating Member iRiot Executive
    1993 S2 V6 VP Berlina
    Jan 2006
    Red Cliffs
    Quote Originally Posted by Cogez View Post
    or you will need to check the wiring harness there in probley a short there probley better then burning it
    1994 Holden VR Acclaim Ecotec V6
    1992 Holden VP Berlina S2 retro fitted with VS Acclaim Interior
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Seems I should never trust what other people tell me about my own car's problems lol
    Brake lights work intermittently, and only when applied VERY hard. Like lock-up-the-fronts hard.
    Faulty brake light switch is my conclusion after a little mess around just now, What can I do? The switch was already at the limit of adjustment and I used to have to brake fairly hard for the lights to come on.... If I get a new switch I'm guessing I'll just have the same problem again? Can I just bend the plate the switch screws into away from the pedal a bit then re-adjust with a new switch??
    Sorry for so many questions
    Sam
    hahaha
    you taste weird man
    WAIT
    WHAT THE SHIT
    chicks all do that
    Sep 2006
    lol i used to think you never used your brakes, apparently i was wrong :P
    If I'd ever seen the brake light switch, i'd be more helpful....
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Drop your fuse panel and you can see it. Screws in and out to adjust, 2 wires attached.
    hahaha
    you taste weird man
    WAIT
    WHAT THE SHIT
    chicks all do that
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Surely somebody knows about these switches...?? Maybe my thread should be called "brake light switch problem".
    hahaha
    you taste weird man
    WAIT
    WHAT THE SHIT
    chicks all do that
    1991_Vn2nV's Avatar
    1991_Vn2nV is offline Donating Member 1991_Vn2nV GTS 1991_Vn2nV GTS
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Dec 2007
    mate, need a new brakelight switch, open the fuse panel the replace it and aujust it so they come on while lightly applying the brake and get new brakelight sockets because chances are they are probably corroded and follow wiring diagrams plug should be ok but globe sockets may be corroded so get new ones while your there from auto pro
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    All of my park and brake lights work (4 and 5 respectively) so my sockets should be OK... I could get the looms at trade price from Holden if I need to though... . ..
    Brakelight switch will need replacing but I'm not sure I'll be able to adjust it right even then... The current switch never worked properly (even at the extremes of adjustment it wasn't sensitive to light application of brakes)... I would have had to screw the switch all the way out of its thread to have it adjusted properly, but then it wouldn't work because it'd fall, if you know what I mean....
    hahaha
    you taste weird man
    WAIT
    WHAT THE SHIT
    chicks all do that
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Had the switch replaced and recalibrated by an auto sparky because I was too lazy to stuff around myself . . . $33. All sorted now though Proud to say I have one of the few VNs with 4 working park lights and 5 working brake lights!!
    Sam
    hahaha
    you taste weird man
    WAIT
    WHAT THE SHIT
    chicks all do that
+ Reply to Thread
  1. brake/park lights vn calais v8
    By ybl8te in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2008, 02:50 PM
  2. Park lights when brake pedal is pushed
    By Greg_Sian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-07-2006, 03:55 PM
  3. park lights don't work - VT I Acclaim
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2005, 09:50 PM
  4. Vh Reverse Lights Only Work In Drive Gear??
    By BoboRobbo in forum Electrical Wiring / Questions
    Last Post: 14-04-2005, 08:05 PM
  5. brake lights dont work
    By adsVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2004, 06:37 PM
