Results 1 to 14 of 14
Thread: vn boot soleniod
    iRiot's Avatar
    iRiot is offline Donating Member
    1993 S2 V6 VP Berlina
    Jan 2006
    Red Cliffs
    Default vn boot soleniod
    can some shom me some pics of where the boot solenoid go's and why i only have one blue wire coming out of it so..
    1. A pic of the postion and what it hooks to
    2. Why there is only one blue wire coming out of the solenoid
    3. A diagram of the wiring
    thanks
    Benwah
    1994 Holden VR Acclaim Ecotec V6
    1992 Holden VP Berlina S2 retro fitted with VS Acclaim Interior
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    ok. u only have one wire on it because it grounds itself when you bolt it to the boot. that one wire is run 2 a switch and the other end of the switch goes to 12v power. i hooked mine up 2 accessories so it can only be pressed and opened when the accessories are on oh, and it hooks onto the boot latch. u disconnect the manual lever cable and hook in the solenoid hope this helps
    heres pics
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    why would you connect it to accessories? then you need the key anyway so you may as well just use the key it would be easyer than putting the key in the ignition then walking back to the other side then back to the boot :P being a vn i'm sure that the solinoid wire is in the boot somewhere just find the black and red wire (i think that is the colour from memory) and it earths through the boot like georgeonboost said.
    13.3 1/4 exhaust only untuned!
    iRiot's Avatar
    Jan 2006
    Red Cliffs
    cool thanks i will have a look and tell you how i go
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    Quote Originally Posted by nathans1987 View Post
    security measure mate. if your car by chance gets broken into they are unable to open the boot that easily...and they cant get thru my ski hatch as i got a gas tank.
    iRiot's Avatar
    Jan 2006
    Red Cliffs
    i try to do this on constant power and it burnt out my switch i dont know wat the *** is the switch only have two things stickin out
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    what switch are you using? it should only be a momentarily switch which means when pressed it pops back out and doesn't stay on.
    iRiot's Avatar
    Jan 2006
    Red Cliffs
    thats wat it is but i think i got an on-off not off-on
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    iRiot's Avatar
    Jan 2006
    Red Cliffs
    yer got it working just needed a off-on switch works bueatyful
    vn 5 litre
    Nov 2007
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    Quote Originally Posted by Gav1802 View Post
    constant power is fine no point if you put it to accessories
    security measure for me mate...i got remote boot release.
    vn 5 litre
    Nov 2007
    vp exec
    Dec 2006
    vaucluse, sydney
    ...and a level of security is offered by installing a on/off switch in the glove box. there is a space in the moulding there (at the top, near where the upper edge of the lid closes into) so that you can stop unauthorised use of the boot release by locking the glove box. note that these things often draw a lot of power (~20A from distant memory) so make sure all your parts are rated appropriately.
    if its anything like my vp glove box a crook would open it in 2 secs... but thats beside the point i guess...
    a hidden switch somewhere else would be a good idea as the boot is the only relatively secure part of the car. my boot release is a lever by the drivers seat = no security at all!
    cheers, pete
  1. boot light stays on when boot is closed
    By seans VL Calais in forum Electrical Wiring / Questions
    Last Post: 25-09-2007, 05:17 PM
  2. boot lip????
    By silver_bullet in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2007, 09:25 PM
  3. Vt To Vx (boot)
    By NVE_069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2006, 12:59 AM
  4. Boot Release not Releasing Boot
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2005, 07:30 PM
  5. variotonic soleniod
    By vscalaisII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2005, 10:02 PM
