Results 1 to 7 of 7
Thread: Braking Problem
    MUNTED6 is offline Banned
    vn berlina
    Apr 2007
    Default Braking Problem
    Hey all i just recently had a prob with me brakes which i was hoping som1 can help i kinda know wat it is but i wanna make sure.
    recently my brakes were really grindy so i had a look and the brakes were metal to metal so it ****ed the disc up. i Recently chenged it and when i changed it the piston ended up suizing up. Si i went and bought disc and caliper from the wreckers. Since then changiung them som reason now the brakes arnt working the pedal goes straight to the floor.
    Which i tried to bleed the brakes and still nothing the brake liught also is showing on the dash board. So im thinking its the master cylinder or the brake booster. Can some please tell me what it is
    THANK YOU!!!
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    To reset the brake warning light, you need to undo the switch on the side of the master cylinder, you will hear the piston click back, then do it up again. You probably have not bled them properly, thats why the brake pedal goes to the floor. The piston probably did not seize in the caliper, it most likely went in crooked and jammed.
    Copied from another thread as I CBF typing it all out.
    1. Place a suitable size ring spanner on the bleed valve. Attach a suitible clear rubber hose to the nipple.
    2. Have an assistant apply pressure to the brake pedal. As he/she does this, open the bleed valve by turning the spanner. Be sure the assistant holds the pedal down. Once it is half way down, have them hold it till you have closed the valve. It is important that you don't go to the floor as this may damage the cups in the M/cyl and you will trip the brake switch again.
    3. Repeat until there are no bubbles in the line.
    * Be sure there is sufficent fluid in the brake resevoir at all times.
    Visit my Facebook page
    vn berlina
    Apr 2007
    if i have try all that and it doesnt work will it possible be a new master cylender
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes. The VS, using the 7/8" master cylinder doesn't have the capacity to move the required volume of fluid for the VT calipers. The VT 1" master cylinder is what is nedded.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Maybe you have somehow got some air right at the master cylinder that usually takes some bleeding to get out if you bleed it at the caliper nipples....but you can do the same thing at the flare nut fittings at the actual master cylinder using the same technique but undoing and retightening the flare nut at the mastercylinder instead of bleednipple at the caliper....its bit messy but you hose it off straight away and its all good.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    vn berlina
    Apr 2007
    thanx for that i will try that but where is the flare nut or nipple at the master cylinder. Also doesnt the v8 also have the 1ich master cylinder?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No, it doesn't.
    The flare nut is the nut that attaches the brake line to the master cylinder.
  1. wheel shaking when braking
    By dewso_18 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-11-2006, 06:47 PM
  2. VL clunk sound when braking
    By STYALR in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-05-2006, 02:17 PM
  3. Vp shakes when braking?
    By PaulW in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 06:19 PM
  4. VT Jolts when braking...
    By chris239 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2005, 10:15 AM
  5. Problem while braking.
    By abzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2005, 08:57 PM
