Results 1 to 23 of 23
Thread: central locking?
    vp executive
    Nov 2007
    lakes entrance VIC
    Default central locking?
    ive got central locking in my vp and want to know if i can make it keyless
    ive got a 1 button remote for my imobiliser
    i know if i can do it i need a 2 button remote maybe some sort of recevier?
    appreciate any help
    [SIGPIC][/SIGPIC]
    Screw the icecream...
    Who wants a moustache ride?
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    my vp had the one button remote and it was central locking. factory. is your immobiliser turned on from the passengers side door jam?
    vp executive
    Nov 2007
    lakes entrance VIC
    yeah it is better then nothing for security my remote only work's once the key's in the ignition and have to use key to unlock the door's
    [SIGPIC][/SIGPIC]
    ratz26's Avatar
    ratz26 is offline worlds oldest noob
    2001 VT equipe
    Sep 2007
    tweed heads
    my immobilozer button on the box on ya keyring is stuffed... can ya just replace the box thingy on ya keyring?
    VP exec ser2 wagon
    Aug 2005
    Mongoose do replacements and repairs on"box thingy"
    Jet pilot your battery in remote is probably flat take it to mongoose.
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    Quote Originally Posted by stockhorse View Post
    or just replace it yourself for a few bux?
    vp executive
    Nov 2007
    lakes entrance VIC
    ok so the single button open's door's and work's for the immobiliser as well?
    battery is easy to replace in those thing's cheer's mate
    [SIGPIC][/SIGPIC]
    vp executive
    Nov 2007
    lakes entrance VIC
    i feel like an idiot now lol changed the battery and watta ya know keyless entry!
    [SIGPIC][/SIGPIC]
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    so that "box thingy" opens the doors aswell? ours has never worked so I wouldnt know
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    vp executive
    Nov 2007
    lakes entrance VIC
    dont worry mate im still dancing around i thought i'd have to do some major wiring job but nooooo woohoo
    i'd say take your's to a holden dealer if you want it to work wouldnt cost much i dont think hmmm but then again they charged me $85 for a vp liscense plate light when i wanted a vn item lol
    [SIGPIC][/SIGPIC]
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I found the remote, put a multimeter on the battery and reads 11.67v and then the button is pressed 11.58v so I dont think the battery is flat (yes it has a 12v battery in it). Is the red LED on the remote ment to flash rapidly when the button is pressed?
    The cars not here at the moment to test again so will have to try later. Im not really fussed about it but would be nice if it worked.
    My (ex)Ride
    vp executive
    Nov 2007
    lakes entrance VIC
    my light doesnt work i found out after i got out and was playing with the button and the door's locked i thought wtf your jocking so i had to do about 5 times lol
    [SIGPIC][/SIGPIC]
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    ah well no luck for me. the light on the remote flashes but nothing happens. turned on the immobilizer in the door jam and still nothing (pretty sure it had to be on). just for the hell of it I tried to start the car with the immobilizer on to see what would happen and "PRESS REMOTE" appeared. I pressed the button on the remote and nothing happened either. maybe I was given the remote to a different car
    My (ex)Ride
    vp executive
    Nov 2007
    lakes entrance VIC
    possible when you stick the key in before turning it then turn key it should start
    yes you might have diffrent one i dont have the key for mine so its alway's on
    [SIGPIC][/SIGPIC]
  15. #15
    VP exec ser2 wagon
    Aug 2005
    If remote does not work properly you can get code from holden and mongoose can do the adjustment.
    jet pilot you need overide key code from holden and to get overide key cut is $10 from nearly any locksmith.
  16. #16
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Just opened up the remote to have a close inspection and noticed something suspicious. I dont know if its ment to be like this but looks like someone has scratched through the tracks on the PCB. I should keep my eye out on ebay to see if I can get another one.
    scratched areas on PCB
    tracks visibly broken
    My (ex)Ride
  17. #17
    vp exec
    Nov 2007
    i have never had a remote for my car, where do i go to get one of these and how do i set it to my vp exec. and what exactly dose that key hole in the passenger door jam do i herd if u lock it then lock your doors ure stuffed.
    long live tha buick motor
  18. #18
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by sackvp View Post
    someone said go to mongoose, but I would like to know where the receiver is and if I can just swap the receiver to suit the remote???
    the key hole in the passenger door jam is to arm the immobilizer. the doors still work fine with it on. your thinking of deadlocking the doors with the drivers door lock.
    My (ex)Ride
  19. #19
    VP exec ser2 wagon
    Aug 2005
    The receiver is passenger kick panel and is rivited in and hard to remove,a different receiver will cost lots more than new remote pad.
    Sackvp that key activates the engine immobilisor and stops the motor being started with out the remote.
  20. #20
    VX S2 S-Pac
    Oct 2005
    this is my problem too, i changed my battery in the remote and it didnt help anything, i can get the locking to work but only once iv unlocked the doors and then i still have to stick the remote right up close to the radio area to make it work.
    Also on a second thort it could be a bad signal coming from the remote and iv seen in dick smiths a remote that can tune to ur old one for $50, might be a good investment
  21. #21
    92 VP Excec
    Sep 2007
    My remote has the scratches as well and doesnt work the locks. Though my scratches are in different spots than azzfox's. Aswell my back door locks play up with central locking. It gives me the ****s when you have to keep checking them esp at night.
    NEED this problem solved soon.
  22. #22
    vp executive
    Nov 2007
    lakes entrance VIC
    yeah my back door's unlock but dont lock lmao
    [SIGPIC][/SIGPIC]
  23. #23
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by jet_pilot View Post
    You might need to get your hands in the door trims there and see if they need some lubricant..
    My mums VP would open but then wouldn't lock the back doors or one usually, Got some spray a little bit of hand movement bend this and that straighten it up and they all work fine together now.. I did replace 2 motors also.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  1. central locking
    By brooksy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2011, 09:41 AM
  2. VR central locking
    By fiendclub63 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2006, 10:34 PM
  3. central locking
    By stewart in forum Electrical Wiring / Questions
    Last Post: 30-10-2005, 02:23 PM
  4. Central Locking
    By Tekka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2005, 02:18 PM
  5. Central Locking
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 07:27 PM
