Results 1 to 6 of 6
Thread: Engine number location
    brett43au Guest
    Default Engine number location
    Hi Just bought a Rodeo witha VP comodore motor in it and I have no idea where to look for the engine number. The Rego has a engine number of VH1088340 but I cant find this or any other number on the motor . Any help is apreciated.
    mixin is offline Ol' fart, young heart!
    May 2004
    Country Vic
    Engine number is right for a V6.
    It is on the front of the motor, below the water pump, on the LHS on the flat front face of the block.
    brett43au Guest
    Thanks I can see a number between the water pump and the pulley on the chank . But it looks like 25533496, is this a VP V6 engine number or a part number for the casting. Again any help is apreciated.
    May 2004
    Country Vic
    Sounds like a casting part number. The engine number is stamped in there, but more to the left, not between the 2 pulleys & it has to start with VH.... Oh - the number is vertically mounted too.
    Also, you'd have to compare it with other motors of the era, but I reckon that engine number is too low to be a VP motor - I reckon it's a VN series 2.
    brett43au Guest
    Default v6 engine numbers
    Quote Originally Posted by mixin
    Thanks this is the first car I have owned with a comodore V6 motor in it and esy way of identifying thediferences between VN and VP series motors.
    May 2004
    Country Vic
    VN series 2 motors & VP motors are near identical to each other. They have the thermostat housing (where the top radiator hose goes) on the front of the manifold.
    Early VN V6s (up to part nov 1990 or thereabouts) had the thermostat in the back of the motor, and a long stainless pipe from the top radiator hose to the rear of the motor.
    That's the easiest way to pick them, but there are heaps of other differences, both internal & external.
  1. Engine Ground Wire Location
    By calais_cruzin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 11:31 AM
  2. Knock sensor location for V8 engine.
    By broderikb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2007, 10:10 PM
  3. 89vn S1 Engine Number Location
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2007, 09:56 PM
  4. Engine Number Location
    By tumoit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2006, 09:09 PM
  5. Engine Number Location On a VP Series 2
    By Madhouse_Dave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2005, 12:39 PM
