Results 1 to 24 of 24
Thread: AirCon - Keep or Remove?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Talking AirCon - Keep or Remove?
    Hehehehe... yeah. I've still got the cheap speed bug. Even after I installed the diff gears, which I SWORE would be my last performance mod... I'm still hungry for more. After my first g-tech (hopefully this weekend), I'm probably only going to be keen on shaving off more tenths
    So here's the situation:
    I have air-con, but am currently short-cutting the compressor with a shorter serpentine belt. I have a tragic cooling issue with my car, but it's managable with the air-con off... ... the second I engage air-con on a 35+ degree day, the car's temperature sky-rockets uncontrollably. As it would.
    So I'm faced with the saddening realisation that my air-con really has no sensible place in my car, except for winter demisting...
    So I'm here to ask for a variety of opinions on what I should do
    Here's a breakdown of pros and cons for removing my aircon:
    Pros:
    Car will be lighter
    Engine bay will be cleaner
    Radiator will see much better airflow
    I never have to get it regassed again
    Cons:
    Demisting in winter will be a bitch
    Hot day + heavy rain and windows up = sweat it out
    It's not a decision that I can turn back on cheaply.
    ... hmmm. Quite the pickle.
    Also, a couple of questions if anybody knows:
    1) Roughly how much would the compressor + condensor etc all weigh? I'm guessing 20kg
    2) What is the safest way to decommission an a/c system?
    3) Any issues that could arise, which I should look out for!?
    Cheers in advance, dudes
    The 1972 HQ Kingswood
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I dont know how much it weighs, I also dont know what it feels like to have working aircon, so Ive survived like 3yrs with no aircon up in Sunny QLD. Depends on where you live etc, are you moving to Brisbane or what?
    Morton's Avatar
    May 2006
    I sure am! Word has come through that regardless of what the boss's decision is on the 7th of Jan, I have a job in the company. So I guess all there is between me and Bris is time!
    Scary thought, really... but it's kinda exciting
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Yay for Morton coming to QLD. Hmm yeah, if you can stick out the heat, take out the aircon. But you already have an issue with the aircon making the car overheat, are you willing to rectify that problem and get the aircon working, or are you just gunna not use it lol, like you are now. Hmmmm
    Morton's Avatar
    May 2006
    Well, that's the thing. If I get a new radiator, I want to make it a GOOD one. I can never justify replacing a broken item with an identical OEM number. I have to upgrade, to make it good value for money.
    So I'd be looking at perhaps buying a $300 aluminium radiator with a high-flow thermo fan. All up maybe a $400 - $500 expense, and that's not something I'm willing to sacrifice for another 12mths, especially seeing as my car still runs in its current condition. That, and then I would have to get the aircon regassed - it's due for it, which is... what... another $150?
    That, and removing the air-con makes everything lighter, and is AWFULLY tempting
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    yep about that..... its definately worthwhile weight removal - but you might as well then also lose the thick rubber pads at the driver/passanger feet that weigh about 10kg as well.... then the deadner from wherever you can find it... and you've lost a passanger's weight all up (at least)
    for you, or the environment? - for you, don't be anywhere near the thing when it's releasing crazy gasses....... for the environment? take ita aircon place to drain the gas?
    other than that, cut and rip is the name of the game!
    sharp edges when you're ripping out all the pipes
    there's also an annoying clip where the pipes run through the rad support.
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    Morton's Avatar
    May 2006
    hehehe, you may find it amusing to find out that my car, in fact, has very little if NO sound deadner left That was all part of my long-winded countdown from 7.6 to 7.18 on the 0-100 g-tech
    Towbar, gone. Rubber mats, gone. Boot deadning, gone. Floor deadning from rear and front, gone. Trans tunnel deadning, gone. Mats up near the firewall, gone. All that's left is the tricky bits I CBF reaching in to chip out, and scrapings on the floor which I couldn't be f'd to heat-gun off
    So logically, the aircon is next
    But yeah, I'm kinda reluctant to take the car to a shop, and pay $50 or something obscene to have gas taken OUT of my car
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Isnt there a release valve up on the silver canister thingo? Woudnt that release it all, but I woudnt recommend doing that because its bad for the environment.
    Morton's Avatar
    May 2006
    The blue thing? I've wondered what that did. But there's no way I would ever do that.
    Ever.
    commsirac is offline Banned
    vx
    Aug 2007
    Deliberate release of r12, which is what the vn would have had originally, is an offence accompanied by four-five figure fines. You could collect it yourself into an empty gas bottle yourself if you had all the right connectors, but proper evacuation involves pumps to get every last bit of it. Possibly this regulation is violated daily at every wrecking yard in the country.
    Sounds like you are trying to turn you vehicle into a racing car by stripping out all the creature comforts.
    VP Executive R-spec
    Jan 2005
    So the thing is if you are a skinny little bugger like yourself (and me) you only need aircon on a day that's over 35c or really 40c if you are tough. Now... how often does it get 35c-40c in Melbourne. Sure fairly often in Summer how often does it get that hot in Brisbane? ? almost never or never so rip it off
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I have never been to Melb, but upon searching wikipedia Brisbane shows hotter temps then Melb, which is what I would have thought also.
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    keep air cond and get a bigger motor that will fix everything. preferably a v8
    13.3 1/4 exhaust only untuned!
  15. #15
    Morton's Avatar
    May 2006
    Quote Originally Posted by commsirac View Post
    But like I said - I would NEVER do a thing like that.
    Ever.
    Quote Originally Posted by greenfoam View Post
    Yah, I can do the 35 thing, no worries. But I don't know if I could to the 35 thing if it was pelting down with rain... and Brisbane is QUITE tropical
    Then again, I could get one of those MASSIVE wind shields that people with walking frames have.
    Quote Originally Posted by nathans1987 View Post
    V8 comes after I shed the P Plates I'm thinking I want to have a bit of money aside first... But yes, at some point, I need a few more cylinders!
  16. #16
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    wouldnt a wind shield cancel out the 20kg loss in weight gain with more wind resistance
  17. #17
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by Mack View Post
    Hotter on average but the Maximums we get in the South are much hotter. We get Northerly winds comming in from the desert that feels just like your girlfriend/wifes best hairdryer on flat out 5cm from your face . There's more days above 35c in a year in Melbourne than there are in a year in Sydney let alone Brisbane, true story. I've lived around Brisbane for a couple years before and a hot day there is nothing comapred to a hot day here, bunch of pussys. Not only the heat but the sunlight here is much stronger and will burn your skin off in an hour about the same as it would take a couple days up North, great for erasing eproms on the cheap but not much good for white people
    Melbourne days per year above 35c = 9 days
    Sydney days per year above 35c = 3.5 days
    Brisbane days per year above 35c = 1 day
    That's average per year as of 2006 or so (it will go up as we ruin the planet some more of course). It quite often gets over 40c in Melbourne. Adelaide is a whole other hotter story
  18. #18
    Morton's Avatar
    May 2006
    Oh man, Adelaide is a DISASTER. They've been known to have straight weeks over 40 if they cop a bad heat wave. All it takes is one stalled high pressure cell, and the northerlies will NOT go away. I should know, I was born there
    But I hear what you say, jase... only it's the humidity that kills you in the north
    But having said all that, and what with me not wanting to be seen as a little girl - I think I'll proceed with the dissasembly of my a/c system
    Maybe.
    And nathan... well, you're right. The wind shield would be something I'd tack on if and only if it was raining. Like an umbrella - kept in the shed for the rest of the year.
  19. #19
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Morton View Post
    might as well take the rear one out as well, seeing as your going to pull the front one, the rear one will pop out to first time you go down the motorway anyways, it will cause to much air resistance.
    rip that aircon out, all the gas has probably leaked out anyways
    Body by Holden, Soul by Brock
    the Legend will live forever
  20. #20
    Morton's Avatar
    May 2006
    Eh? I don't HAVE a rear one... or a front one. That right there, was a hypothetical.
    And yeah, I suspect that air-con doesn't have much if any gas left in it...
    ... especially not any.
    at all.
    >_>
  21. #21
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
  22. #22
    Morton's Avatar
    May 2006
    No, I was called into work just after I posted that - and now I'm back at home, it's ****ING down. Looks like it'll have to wait for the weekend
    Damnit
  23. #23
    Crunkz0r's Avatar
    Crunkz0r is offline Wagon driver
    VR exec Wagon v6 auto
    Sep 2006
    Are you kidding me? i'm pretty sure from memory there was more than ONE day over 35 degrees in brisbane and like you said, ona verage anywhere south of Bris is almost always colder than brisbane, i come from adelaide and been in adelaide for their 40 degree weather and its just hot and dry where as up in qld it is hot and humid, the humidity brings the storms and while it is raining and storming, it is still extremely hot and u cant exactly have ur windows down in the rain. That is what gets u without air con on them hot humid days.
    But if u do take the aircon out, you should get a weather shield for when it rains, but weathershields really are ugly. A Mate of mine re-done his own air conditioning and it is very cold and comfortable on a steamy hot day.
    [SIGPIC][/SIGPIC]
    Very nice... How much?
  24. #24
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    Really, in a road car, you want to keep the A/C...otherwise, in the middle of summer the heat will drive you crazy.
    If the car's mostly for track/race/motorsport use though, pull 'er out.
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
  1. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  2. VS AirCon
    By Quicksilver in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2006, 05:53 PM
  3. vr aircon
    By craigvl038 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2006, 08:16 PM
  4. Vk Aircon
    By SLIPPERY PIZZA in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-09-2004, 08:10 PM
  5. Aircon
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2003, 11:17 PM
