Results 1 to 12 of 12
Thread: Air Con on in Drive and car stalls?
    Jul 2005
    Default Air Con on in Drive and car stalls?
    Hi all,
    Finally warm enough to have the air con on in Tassie. I have a vp commodore auto with about 260.000 km. Today I turned the air con on once I was driving. The car stalled when I pulled up at a roundabout. iAir con off and into neutral or park and it started fine. I could even turn the air con on. Put it in drive and it stalled. Happened every time. Even when driving at speed with the air con on was ok as long as the revs were kept up. Come of f the throttle and the car would stall.
    Anybody got any thoughts? Any and all comments greatly appreciated.
    Jock
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Something wrong with the aircon pulley/clutch that its putting pressure on the motor and causing it to stop on idle? Any squeeling while it was happening, how long since u last used the aircon?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, sounds like the engine's struggling to pull the aircon pulley. Perhaps it's time for a new compressor?
    The 1972 HQ Kingswood
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    It sounds like the same thing that my car was doing before I replaced the compressor, since replacing the compressor it hasnt happened once.
    commsirac is offline Banned
    vx
    Aug 2007
    Correct me if im wrong but idle speed on the vp is controlled by the computer and any additional loads will be taken care of in the idle compensation mechanism, perhaps something is not working here or as suggested the load from the compressor is extraordinary and beyond the operating range of the idle compensation.
    Did the idle speed drop when turning on the ac whilst in neutral?
    If the motor didnt slow down then the compensation is working, but perhaps couldnt cope with the extra load of putting it in gear as well.
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Just adjust the idle screw abit. Looks like you will need a new compressor mayyybe get away with a new bearing if the old one is really bad...
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    Quote Originally Posted by Wavez View Post
    I might be way off track here but if you adjust the idler screw wont the computer just bring it back down anyway when you restart? Isn't that what the system is about?
    If you keep winding it in you'll get to the end and the computer will keep compensating until you have to wind it back again causing the car to not run.
    Someone will correct me but seems logical...
    I'd say something wrong with the compressor.
    Chirpstr's Avatar
    Sep 2007
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    Chirpstr's Avatar
    Sep 2007
    Chirpstr's Avatar
    Sep 2007
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    dunno mate. used to jap cars where they are different things. My commy only had the one though.
  1. series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2011, 11:49 AM
  2. to drive or not to drive- shredded cable
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2007, 05:16 PM
  3. Help car stalls
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 08:37 AM
  4. H E L P me!! my vpss v8 auto stalls in drive!!
    By Dasampsta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2006, 07:26 PM
  5. my vt stalls
    By hikvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2005, 07:12 PM
