Results 1 to 3 of 3
Thread: Now it stalls in drve without the aircon on!
    Jul 2005
    Default Now it stalls in drve without the aircon on!
    Yesterday I posted about my vp auto stalling with the aircon on in drive. Thanks for the replies. I was about to investigate the answers today but guess what? Now it stalls when in drive whether the air con is on or not. If I can get going , by starting in neutral and putting some revs on I can pull it into drive and off we go. Come off the throttle for a roundabout or lights and it stalls again. I think something is wrong with the idle speed control as it is a bit slow and lumpy when in park or neutral anyway.
    Any help would be greatly appreciated. I have a manual and a space to work (and luckily enough another car)
    Jock
    VN SS 5.0
    Aug 2007
    what are ur revs sitting at in park?
    maybe ur revs are too low and wen u put em into a gear they drop slightly so mayb try adjusting them in the engine near ur throttle body just tighten that screw on the valve behind it and see how u go.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    It's possible that your AirCon pulley could be shagged to the point where the clutch is still somewhat engaged and causing resistance when off. It's hard to say - but given that your AirCon spawned this problem, it's quite possible that this is the case.
    Easiest way to tell, would be to take off your serpentine belt, and spin the AirCon compressor wheel around. Tell me how hard it is to turn - it should spin freely.
    The 1972 HQ Kingswood
  1. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  2. stalls on gas sometimes?
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2007, 06:06 PM
  3. Help car stalls
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 08:37 AM
  4. stalls when hot
    By radiohead in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2006, 10:40 AM
  5. my vt stalls
    By hikvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2005, 07:12 PM
