hey guys just a quick question,
i have a vp wagon, v6 is shagged, so im looking at either another v6, or a worked v8 carby engine...now if i got the v8 carby option what emissions would i need being a 92 model car with a older carby v8? i would like it legal
no chance ever getting it regoed with the carbied v8.. if u want an 8 put in a injected 5 ltre as its legal if u get one out a vp or l8ter and it will produces more power then the carbied 8 or just go buy another v6 for 500 bucks
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
fair enough just thinking about my options
ive got a 5ltr motor but da wiring loom shat itself
what you after for it
pm me n offer, ive got everything to make it work, just needs new wiring loom
heres a trick question and something i had thought about doing a few years back before the stroker and turbo kits were available for the v6 but what if you grabbed a 253 and placed the 304 efi gear on top?
Can be done, few issues though. Because the port order is different between the carby and efi V8's, you have to use the VN onwards heads and cam before an efi manifold will fit. You also have the issue of most (if not all? Can't remember) 253's being trimatic pattern, so you need to modify the block to fit the T700 box.
Once you've got all that out of the way, it's still probably not legal. I'm not sure how true it is, but I keep getting told that you can't use pre-emissions control blocks in an efi application because the RTA ID's the engine by block number, and if the block number is for an engine that doesn't meet the emission standard applicable to the car, they assume that the engine doesn't meet the standard. Even if you've brought it right up to efi spec. Seems stupid to me, but in my experience the RTA is stupid, so I'm perfectly willing to believe they'd do that.
Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
Luke Duke: You mean you're gonna make sweet love IN it.
Beau Duke: Oh no, I'm gonna have sex with it.
yeah thats what i thought
For what it is worth, addressing the OP: yes, you can fit a VL spec. carb. V8 into a VP because the emission laws applicable are the same. Why you would want to is another question.
The EFI heads onto a 253 (in a VP) is definitely not legal. Bringing an earlier 308 up to VP specs. can be OK, providing all the emission parts are present.
You can do it if you run straight lpg, or a VL 304 motor (which will be slower than the V6). Apart from that you can do the sensible thing and just put a injected 304 in it which is stronger/faster/better, just better than the earlier motors. Probably the best and easiest option would be a ecotec
Where are you? I have a fresh 5 Litre VN (Complete car) that would be perfect for the project. Body is fair (no damage just rough) but mechanically it is great. PM me if interested.
Cheers,
Reaper
