Results 1 to 3 of 3
Thread: how to take off outta rear window moulding on a vp
    NO CAR ATM.. -.-
    Jul 2006
    Default how to take off outta rear window moulding on a vp
    andd how do you take this off too thats on the pik
    Attached Thumbnails Attached Thumbnails how to take off outta rear window moulding on a vp-dsc00019.jpg
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    i assume the same was as the vn? but considering the vp ones moulded to the window you have to remove it in 1 go, they'res 3 plastic nuts behind the plastic panel in the back and then 3x screws and thats all that holds it in
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    That bit is a piece that hides the join where the 2 panels meet.
    It has 2 pins cast into that covering piece that sits in holes in the car...problem is that they are glued into the holes with poly urethane....so you slide something narrow in behind it and SLOWLY work the pins out of the holes... dont be tempted to grab it by the ends and violently pull on it because it will break,
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. Oil leak and door moulding
    By cart in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-01-2008, 05:45 PM
  2. VS Ute red body moulding
    By BowTieGQ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2006, 12:31 PM
  3. how to fix door moulding For VT commo
    By tariqzvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2006, 08:02 PM
  4. In Need Of Rear Moulding For Vk Calais
    By vs_ssboy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-06-2005, 12:21 PM
  5. Rear window seals are coming loose, window is rattling whilist driving.. how to fix??
    By t3zza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2004, 11:58 AM
