Results 1 to 6 of 6
Thread: Bonnet Latch
    HSV VS Senator / HQ 5.0L Tonner
    Jul 2005
    Mandurah, W.A
    Default Bonnet Latch
    just went to pull my bonnet up, pulled the lever inside the car (near my pedals) and nothing is happening :S it pulls out but my bonnet doesnt pop up.. i've tried shaking bonnet, pulling on bonnet whilst someones pulling latch and i've just tried wiggling it around tryin to get it to pop, but it wont :/ is there another way to get it up?? wat can i do lol
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    You have two options. If the cable is not broken or disconnected and is just stretched try leaning on the bonnet and pushing down on it while someone is pulling on the leaver. If the first method doesn't work, get underneath the center of your car at the front and look up, you will see the bonnet pin, this pin has a slit in it. Put a flat head screwdriver into the slit and undo the pin, once the pin has been undone the bonnet should open.
    missus (in more ways than one)
    Sep 2005
    i had this problem, if you have a second person around, like mentinoed above get them to pucsh down on the bonnet while you pull the latch, or if no one else is around, hold the latch open and give your bonnet a good smack with a closed fist, very ghetto but it works
    Jul 2005
    Mandurah, W.A
    VRII 94 Exec
    Mar 2011
    Hervey Bay
    Why give false information. The pin is above the radiator. you can not see it from under the car. Im going crazy, bonnet cable snapped. Will not open
    few commodores
    Feb 2011
    victoria
    Quote Originally Posted by VEEARR View Post
    you can see it, look up through the bumper, in front of the radiator/condenser, undoing it with a screw driver will most likely be difficult due to the lock nut and it probably hasn't been moved in 20 years.
    now if the pin was above the radiator you'd have a hole in it when you closed the bonnet.
    another way that is a bit awkward is to get a screw driver in behind and push the latch, this method is fairly difficult due to the design to stop ppl from doing it.
  1. need help! bonnet latch is broken and cannot open bonnet!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2012, 11:10 AM
  2. bonnet latch replacement vn
    By steveabbott in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2007, 07:22 PM
  3. Bonnet Latch prob
    By VNSSMAN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 03:20 PM
  4. Bonnet Latch
    By Gav95VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2004, 08:23 PM
  5. Boot Latch Is Stuck
    By Du`ranain in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-10-2003, 08:09 PM
