Results 1 to 5 of 5
Thread: ruff starts
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Default ruff starts
    Hey Guys,
    As of late when i am starting the car up its a bit ruff, Sounds like its got a top fueler cam, if you give it a bit of rev its still missing so i generaly let the car sit for its usual 1-2minutes to warm up and its all fine and drives like a dream.
    Also the engine light on the dash does show up and that dissapears once the ruffness goes away, it does dissapear after 5-15seconds.
    Any advice or things i can look over, Coolant is still nice and high, Oils are great, Plugs & Leads could do with a new set, Air Filter brand spanka!
    Nothing in my fuel system has been changed in the 5years ive had the car also.
    Thanks!
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    i would start at plugs and leads ....then fuel filtre and maybe coolent temperature sensor as thats what mine was doing...also give it a diagnosis to tell if there are any errors (codes)
    anton1o's Avatar
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    What type of leads/plugs are people running here?
    Ive got topgun leads on a set of gm plugs, Ive seen NGK's but would Iridiums be good for the VN?
    VP exe
    Sep 2007
    tog gun and GM are pretty good.
    doubt its that, unless they are older than 4 yrs.
    Im running eagles, but had topgun on the VN.
    Everyone was ravin about eagles, personally I think the top gun 8mm spiral where a much better lead and better build quality too.
    I just replace my pluggs, when I pulled em out they were GM but I put NGK in and didn't notice any difference between the old GM and the new NGK.
    cheers
    Gone Fishing...
    XTC16's Avatar
    XTC16 is offline Certified Wise
    Foot Falcon
    Apr 2006
    Brisbane - South Side
    QLD Ignition Leads, best thing you'll ever lay your hands on.
    [GMJ37] Another Commodore .... another dollar ....
  1. Are they really so ruff?
    By VL Berlina 5speed in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 08:38 AM
  2. running ruff
    By vpssguy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 03:53 PM
  3. ruff idle?
    By CNULTR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-09-2006, 09:54 PM
  4. ruff riding ve...
    By andyman in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-07-2006, 08:17 PM
  5. runs ruff need help
    By way in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-07-2005, 11:39 AM
