i looked at my fuel injectors and i noticed they were all loose and such i dono if its ment to be that loose but i jus wanted to check. and also a mechanic checked em over and said they were leaking air at the base so they wood suck air in i dno wots caused this but any feedbak wood be sweet.
go to repco and you can get a couple of box's of rubber o-rings for a couple bux each and go thru and change all the o-rings on the injectors, its a very easy job to do
"A life lived in fear is a life half lived"
sweeeet cheers
