Peoples? and how much would i be looking at?... ta
do you want a higher volt or a higher ampage? if you want a higher amp call an auto electrician and they should be able to build you a higher amp alternator to what you require. as for the higher voltage if you go higher then the stock you will start to blow fuses and damage equipment in the car.
1986 vl berlina turbo
1981 te gemini panelvan
Yep, ^^ what he said. You can't get a higher voltage alternator, only higher amperage.
G'day
The last one i did cost around $350-$400,depending on what sort of alt you have its a simple matter of buying a BOSCH BXU 13012 alt from memory,and if your car is up to VP swapping the internals.
The other thing to do is to run an extra battery feed to the + terminal on the alt to handle the 130 amp alts output.There is a madification that can be done to the alt stator connections (DELTA the connections on the leads) but this has the down side of the alt needing to be driven faster to get it to "kick off" ie to start to charge and requires more revs to keep it charging,so in other words when ya cruisin around with ya DOONK DOONK goin full blast you will need to haver it in 1st gear to keep the revs up
Regards. Phillip![]()
hey phil are you an auto elec dude
yepstarted way back in jan 1972 as an apprentice,the only electronic component was an am radio and that was an optional extra LOL
Phillip![]()
cool im an elec fitter but have rewound a fair bit of 12v alternators and armatures its nice and easy compared to 3 phase motors
