Results 1 to 9 of 9
Thread: VP coolant sensor?
    VP exe
    Sep 2007
    Default VP coolant sensor?
    Anyone know where this is located, (series II)?
    not the same as the series I.
    I have the TB off atm and just replaced the IAC and am replacing the coolant sensor if it even has one,
    (repco sold me one so I guess it does).
    thanks
    VN Calais 3.8 VH SL 3.3
    Jan 2007
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, you've got two.
    Coolant temp sender for the ECU
    Water temp sensor for the dash
    single wire one is for the dash gauge, dual-wire one is for the ECU. Good idea to replace both, and they're both in the same spot behind the Alternator Shouldn't set you back more than $25 for the two.
    The 1972 HQ Kingswood
    VP exe
    Sep 2007
    thanks guys
    I replaced it and the IAC as well, it actually made the whole car a lot smoother, aparently the coolant temp sensor acts on fuel mixture, so it helped.
    but it didnt really stopp the problem I have with excessive revs on startup so I am looking into it further, could be the TPS.
    this stuff really gets me because it is somthing simple I know its just a matter of finding it.
    I will replace the other one tommorrow as I only replaced the Coolant temp Sensor.
    Guess i could stop being so bloody lazy and get out the trusty ol manual and multimeter.
    thanks for the help
    cheers
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    excessive revs on start is in the ecu because when your engine is cold the ecu is telling it to idle higher and once up to operating temp it will drop back to your normal idle.
    but how high is going
    VP exe
    Sep 2007
    It only does it when hot, not sure how high but it sounds wrong (probably up around2000 rpm).
    Im checking for vacum leaks today.
    Gone Fishing...
    VP exe
    Sep 2007
    Just thought I would post another question, since I can't seem to find any vacum leaks.
    It only does it when hot, like when its been drive for about 10 minutes then stoped then I restart it, like at the shops.
    The idle rides up and sits there , then goes down and rides up again when I take it out of park and put it into revers or drive.
    any ideas or tips as to what to look for,at the moment I cant find a leak.
    why would heat be affecting it and gear changes from park to drive..?
    so far i have replaced coolant temp sensor(new).
    TPS (just swaped over from another TB).
    AIC sensor (new)
    adjusted the kick down cable (its fine)
    coils all good resistance
    cheers
    Gone Fishing...
    Black VN MANUAL
    Feb 2007
    Top of Vic
    could be CAS, check the ECU for any codes see what it gives ya, its worth a shot sounds like a sensor though so you replaced the IAC even though you replaced the TPS big possibility that it could be it. good luck
    VP Vacationer wagon
    Feb 2006
    The coolant temp. sensor is located under the alternator. This means you must remove the alternator to get it out. You will also need to drain the radiator, and disconnect the battery. You may also need a special socket to extract the sensor from the motor.
  1. Coolant sensor VR V6
    By acclaim94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2012, 12:03 PM
  2. where is the coolant temp sensor??
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2007, 01:43 AM
  3. VP Coolant Sensor
    By Cobez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-09-2007, 09:22 PM
  4. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  5. Coolant temperature Sensor
    By cacaman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2006, 11:48 AM
