Results 1 to 11 of 11
Thread: Need help servicing injectors
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    Default Need help servicing injectors
    Just pulled out the injectors in my cousin's VN and bought a repair kit which had a few bits and pieces in it and we were wondering about a particular bit that goes into the very top of the injector. We don't know how to remove the old one so we can put the new one in, cheers. Here's a pic btw
    VP Executive R-spec
    Jan 2005
    That's the filter basket, I think you need a tool to get them out but I'm not sure. I'd like to know also if anyone does know and where you got the kit from!
    VR Berlina wagon
    Oct 2005
    Thumbs up filter removal tips?
    you're right, it's the filter! - having seen the removal tool in use - it looks like a small self tapper with a handle (screwdriver with a thread on the end?)
    I would assume that it would be easy enough to make one, but just pick a screw that is a bit bigger than the hole in the plastic sleeve and screw it in a couple of turns and use a pair of pliers (vise grips) to pull the filter out...
    have fun now...?
    Apr 2006
    there is a tool to get them out, which makes it easier.
    if you dont happen to have that tool, screw a smallish phillips into the filter, a fair distance down, and then use a pair of pliers to pry the filter out =)
    Apr 2006
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Any auto place.
    Yeah I just stuck one side of needle nose pliers down until it wedged them pull out sideways, They come out easy then.
    Yours Kindly,
    Jim
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Hmmm, so is it worth doing? How dirty have they been when you've pulled them out?
    Feb 2007
    WA Perth, Joondalup
    We got these kits for $10 each from Coventry's (in WA). Each kit does 2 injectors (4xO-rings,2xWashers,2xFilters,2xNozzles), so we bought 4 kits for the 5.0L.
    You usually have to get these ordered in cos they are a specific part. I'm sure Ripco can also order these in.
    The main reason for doing this was to replace the O-rings because there was an air leak in some of the injectors, I'm not sure how much changing the filter helps.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Ive got a pack of 100 O-Rings at home, but im mainly interested in the filters being clogged. I may have a look into these kits anyway
    Feb 2004
    NSW, Australia
    Quote Originally Posted by Mack View Post
    Well mine weren't dirty at all. I suppose running premium all the time would have helped. But I did it as preventive service. But what I did after I took the baskets out, I filled up a chinese food container with injector cleaner and sat the injectors in this overnight. Next morning the injector fluid wasn't so clear. It was a bit murky. So I might have archived something.
    Yours Kindly,
    Jim
  1. vs servicing
    By pr0n in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2007, 11:57 AM
  2. servicing
    By Chaddy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-12-2006, 08:46 PM
  3. servicing ya car
    By vnbelina in forum General
    Last Post: 03-04-2006, 09:31 AM
  4. VS Servicing
    By BlueBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2005, 09:41 PM
