is there a way to test that the fan in my v6 is working ?????????
Hey Slayer,
If you remove the cover under the glovebox i think the power feed wires for the A/C fan are up the top fairly large 5mm i think,blue & yellow from memory, put a test light across them and operate the switch you should'nt notice a great difference in the brightness of the globe,is you car fitted with climate control? hope for you sake its a switch or relay.
Reagrds Phillip![]()
Another quick an easy test is
Turn on the air con when driving (probably when stopped on idle too),the fan should come on.
cheers
sorry just reread the post, I was refering to the cooling fan behind the radiator...which is not the air con fan.
Gone Fishing...
