hey, my mate has a vp and there is a very annoying noise that sounds like it is coming from the dash it sounds like trickling water or sumthing, it only happens when the car is moving. Has annyone had this problem or knows what to do to stop it. it is really annoying help will be much appreciated cheers!
Make sure the a/c drain aint blocked thats about the only thing that springs to mind.
Regards Phillip![]()
its the water from the heatercore passing into the cabin (right behind the headunit) if the'res air in the system it can cause this, try just filling up your radiator cap all the way, (when cold) turn the car on let it idle
i got the same sound thats the only thing i can think of just air in the heatercore system
i was gona ask about that noise cps its annoying as hell and has only just started doing it in my car, it used to drive me nuts on my other VR and now its back :@
ay thanks heaps i took the cap off filled the water right up let the car run for bout 15 mins wit the heater onn and yer the noiise went away i also noticed that a few times the water level in the radiator droped down is that normal or do i like have a blockage or sumthing oh aswell there was heaps of dirt in the water i might drain it and refill the whole system.
i have the same sound in my vs too just wondering do you keen the radiator cap off while letting it idle man?
cheers!
this thread reminds me of a super cheap add... check the ash tray for ear rings...
