Results 1 to 13 of 13
Thread: Rear Main Seal
    Jan 2004
    Not my car, thank heavens, my bf's brothers car, he claims that he has an oil leak, he has taken it to his mechanic friend, who said that it was a seal in the back of the engine somewhere, Anyway, i know that rear main seals are a common problem in VN's but he was quoted $2500 to rebuild the engine, this wouldn't be necessary would it? Or is there another seal that qould require alot more work and be very costly???
    MaNiac_VP is offline Mr Moderator !
    VPII Calais
    Oct 2003
    QUick question.
    Is it a VN or VP engine?
    VP engines are pretty easy to change the seal, you have to jack the car up and then its in full view and easy to change.
    VN series 1 is a lot harder to do and I stuffed up the first time i did one and made the seal even worse and had to pay just over 600 bucks to get it professianlly fixed.
    Unless the engine is rooted, why would he need a rebuild??
    I'd goto a few places and get some quotes.
    OSL-060's Avatar
    OSL-060 is offline Banned
    Dec 2003
    SE QLD
    Exactly what I said in messenger
    I think it's got a shagged bearing, or so the mechanic claims.
    Jake.
    Jan 2004
    not exaclty sure why, but i believe that this mechanic has his hand on it a bit, thats maybe why he shut shop christmas eve. But i will get the full low down of the real problem when i see them next, i doubt they even have a major problem like they claim.
    Also it is a VN, not a VP, i believe that it is possibly a series 1 also, but as i said, i will get the full details tomorrow
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    .::Crocodile Hunter::. Guest
    QUOTE (MaNiac_VP @ Jan 8 2004, 12:41 AM)
    arr changing the rear main seal, Gearbox must be removed so it is not as simple as you might think straight foward job though.
    CODE leaky main seals are a terminal problem with the holden v6 i believe
    not allways depending on how many k's the motor has done. remember seals get old and crusty with age and will start to leak.
    heres an image of a rear main that i replaced in my VP about 2 months ago allong with the Ring Gear, didnt replace it cause of leackage. i changed the Rear main because i had to pull the gear box out to replace ring gear, any time i pull out a gearbox the rear main gets replaced whilst i am there, i will leave it if it is kinda new oil you see is mainly from the damm Sump :S
    VPII Calais
    Oct 2003
    QUOTE (.::Crocodile Hunter::. @ Jan 8 2004, 09:17 AM) QUOTE (MaNiac_VP @ Jan 8 2004, 12:41 AM)
    Actually you'll find you only have to drop the pan really. It's still not an easy job, but definately easy in comparison with early VN engines!!
    No need to remove the whole tranny!
    Gives you an excuse to service the tranny while your at it thow.
    OSL-060's Avatar
    Dec 2003
    SE QLD
    Quick slightly OT question for you Paul
    So the series I VN rear main can be done with the box out, without having to hoist the motor?
    Jake.
    VPII Calais
    Oct 2003
    Nah mate series 1 is a prick, you have to pull the engine out to get to it.
    Cost me about 600 bucks all up. Prolly more usually but I'd already removed half the engine.
    VP can be done with the tranny pan dropped, but i think you have to drop the tranny if its a manual cause the flywheel gets in the way?? Not 100% sure of that, just what I have been told by someone on here I think.
    Never touched motors after that, but the VP is definately easier.
    You can just pull the seal out with some small pliers.
    VPII Calais
    Oct 2003
    ACtually come to think of it, maybe with series 1, if you removed the tranny and flywheel you'd be able to do it.
    I never tried that as I didn't want to remove my whole transmission.
    OSL-060's Avatar
    Dec 2003
    SE QLD
    Thanks Paul, I'm pulling mine to do the clutch and inspect the t5. So may aswell do the rear main while I'm there.
    Jake.
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    well, the bad new's is i saw rebels b/f's brother's car, and i must say, it's not to good, it has the all familiar rattle from the rear end. it's thrown the rear crank bearing, or spun it, either way it's not good, and yeah, it has a nasty oil leak at the back, it's a series one vn. it has a few other engine problems, i removed the oil cap while engine was running, looked in, no oil flow threw there at all, the bloody thing is starved for oil, but there is no oil pressure light on in car. i have recomended a new engine, dont rebuild the one that's in it, it's block will now be rooted.
    i am the god of britany spears womanizer on just dance on the wii
    Grantis1976 Guest
    An american importer from Brissy tells me that these V6 motors have been a problem since there fisrt incarnation, way b4 we were born. Below is a list of Commies that I personaly know of that have had the rear main replaced / or needing it real bad !!!
    Series 1 & 2 VN
    ? ? VR
    ? ? VS x 4
    Series 1 VT
    " 1 VX x 2
    Not a good record, but it all comes down to part of the maintainance.
    Good Luck To All in this situation !!!
  1. Rear Main Seal
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2007, 10:01 PM
  2. Rear main seal in VN 5lt
    By vnberlwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2006, 08:46 PM
  3. What rear main seal to use in hot 253
    By Mattie77 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2005, 05:20 PM
  4. VR Rear main seal
    By Ute 94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 09:47 PM
  5. Rear main seal on 5 ltr
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2005, 10:19 PM
