i was told by a guy on you tube that it was possible to install a vr ecu into a vn so you can get the faster ALDL and run real time stats. The ecu plugs straight in but you need to add a wire or 2 so you can get the ALDL plug from the vr to conect properly, so my question is has anyone done this mod and would anyone know what wires need to be added. Also would i be able to still use my vn chip.
