howdy, anyone got any ideas what is ticking under my bonnet its not there all the time can come on start up could it be a sticky lifter
what do you reckon
i reckon the my ride section isnt for posting about the problems you're having with the car.
can you describe the ticking noise in more detail? could be lifters, injectors, tensioner pulley, all sorts.
yeah sorry mate wrong box again
the noise is there on start up and gone after a minute
could be a noisy lifter any additives axailable or any ideas
running pennzoil 15 w 40
15 40 is to thin and will make the engine make ticking sounds take it out and put in some 20-50
~ VN POWER ~ Click the scales
Also, before your next oil change, run some engine flush through it to clean all the lifters etc, I did this and took off the rocker covers to find they were clean as! So it works. If its not that, it will probably be your injectors.
Run the thicker oil, it's your rockers. My car does it when its getting low on oil.
id say itl be lifters. there is actually "lifter free up" additives out there. every now and then may get it actually working on a car. could be worth a try after your next oil change to something a little thicker.
hydrahlic lifter
common, they all do it
Gone Fishing...
yeah thanks guys
will try something thicker
ticking only started after i put 10 w 40 in
lifters are probly gooooooorrrn
A thiner oil will do that its an older engine not a new car needs abit more thicker old. if not take a rocker cover off and check the rockers see if there move abit might need to retorque the bolts down mine did it alot. hope this helps
Being a VN which is a 20 year old car,it sounds like a noisey lifters,there isnt much an easy fix you best chance is to replace them,you could try adding
500ml of auto transmission oil to the engine oil and run it for at least 1000kms before changing the oil and filter,i would replace it with a 20w 50 or even a 20w60 grade of oil.The auto oil helps breaks down the build up of burnt oil in the engine and may also help loosen a stuck lifter.But it isnt a garantee,suggest replacement of all lifters.
