Does anyone know the individual weights (kgs) for the V6 motor and Auto transmission? I want to buy an engine crane and engine stand but there are several you can get depending on the max weight.
500kg engine stand will be fine
1250kg crane will be okay to pull both out, but you'd be better off going for 1500kg + so you get a bit more comfort with the extended reach of the crane arm.....
