Results 1 to 20 of 20
Thread: T700 weak?
    EF Almost Turbo
    Jun 2005
    Default T700 weak?
    Hey
    Just thought I'd have a ramble.. the VN's transmission died back in august, so i got a changeover one which was in GOOD condition. Now, the exact same problem has come up as with the first one.. its delayed when going into reverse from anywhere (Park of either Drives) and when its cold it doesnt change the best.. its USUALLY alright when its warm... once it slipped into neutral..
    Are T700's really that weak? Or am I just pushing it too hard? :P
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    From what ive been TOLD, they are a quite strong box, but I too have my doubts. I had been through 2 in the VN and the GTS had its loose 3rd gear. I have had the GTS one rebuilt with a heavy duty drive shell and other parts, its really holding its ground now though.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    there pretty good transmissions, it's just the way GM designed em to give a nice long smooth shift, it's actaully bad for the box because when things slip(during the shift) they wear out. better off getting your box reco'd with some decent parts and get a shift kit and corvette servo and it will live a long happy life. also a regular service won't hurt it either. another good addition is a decent transcooler. the factory one is pretty average
    Body by Holden, Soul by Brock
    the Legend will live forever
    EF Almost Turbo
    Jun 2005
    Quote Originally Posted by immortality View Post
    Yeah, I was considering that until I lost my job.. and it has been serviced.. next service is due in 10,000km... its just losing power again..
    DaZ
    The_Monk says:
    im a leech
    VL-187's Avatar
    VL-187 is offline ZZZZZZZZTUUUTUUUTUUU
    XR6 turbo 332rwkw
    Jan 2005
    there a pretty strong box, just not the smoothest i recon...
    like immortality said, have it reconditioned with a shift kit n corvette servos n it will be much better... i plan on doing that very soon...
    vp executive
    Nov 2007
    lakes entrance VIC
    the t700 is standard in the vp v6's am i correct? i think they are dam tough ive givin mine a hiding and found out the previous owner flogged it as well for 6 year's not a problem im going to get it rebuilt when i get a stage 2 shift kit and vette servo tho
    [SIGPIC][/SIGPIC]
    Screw the icecream...
    Who wants a moustache ride?
    VN S2 V6 Berlina
    Apr 2007
    That set of symptoms seems quite common throughout past posts. Mine does it as well.
    Has anyone been able to fix the slow engagement of 1st/reverse in their box without going to a full rebuild?
    Might it be low fluid pressure, blocked oilways, easily blocked filter or degraded trans fluid?
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    worn clutch packs and low pump pressure combined cause slow engagement into 1st/reverse.
    EF Almost Turbo
    Jun 2005
    Yeah, ive been told the pump is responsible... last time i just changed it... but this time i cant even do that.. might try replacing the pump..
    DaZ
    The_Monk says:
    im a leech
    VS 355 Turbo, VN Calais 5L, VE SII SV6 Wag, Mirage
    Aug 2006
    Adelaide, SA
    they are weak i have killed 2x T700s in my VN and i drive it hard but not stupid and i do look after it
    they are only strong if u spend the money to strengthen them in stock form they are a waste of space.
    vp executive
    Nov 2007
    lakes entrance VIC
    in a 8 they probly need strenghtening but behind a 6 they are good but i think anything over a mild motor they need work but that's the same as all the driveline
    everyone know's you cant have a weapon of a motor and stock box n diff and drive shaft it just wont hold up
    [SIGPIC][/SIGPIC]
    VP exe
    Sep 2007
    Anyone got any info on corvette servo?
    like where to get one and how to install one?
    and cost.
    cheers
    Gone Fishing...
    VP Executive R-spec
    Jan 2005
    ebay, easy and 40 bucks. They come with good instructions and bolt into the side of the box, here's a demo
    YouTube - VP Commodore 0-60 mph, slighty damp road
    VP exe
    Sep 2007
    Thats pretty neat, the wheel spin makes the speedo jump up a bit quick, but it evens out over 100k.
    I dare say that car has quite a bit of power.
    cheers
    Gone Fishing...
  15. #15
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by Just_a_stocker View Post
    cheers
    Nah it's just stock (like your name ), 150ish rwkw. The road had damps patches on it that's why the wheels started spinning on the hard shift. Interesting how the torque runs out at 4500rpms and wont go higher though
  16. #16
    vn calais, vs clubsport #137
    Jun 2005
    my vs 5 litre does that in the dry with 205 15" wheels on the back, i have to throttle off then ease back in to avoid spining to much. not so much fun :\
    that is runing only a strengthened auto with std servo piston
  17. #17
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by vn calais manual View Post
    Get some 17" and then you'll feel more safe
  18. #18
    Jun 2005
    have 17"s its a clubsport. just had stock wheels on the back while geniune rims get repaired. amazing what difference tyres make.
  19. #19
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Ahhh, got ya. U just said VS 5Litre, didnt know it was a Clubber.
  20. #20
    VP Executive R-spec
    Jan 2005
    Yeah tyres are where it's at, but I believe (until proven otherwise) I have set the fastest 60 foot time at 2.06 from a unopened auto 5 litre in the country on those same tyres in the video
  1. piss weak fordv8z
    By commisme in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-12-2006, 04:27 PM
  2. How weak is weak
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2006, 10:56 PM
  3. Weak brakes!!
    By keza87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 10:01 PM
  4. Weak Headlights
    By craige1982 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2006, 11:29 PM
  5. Weak VB!
    By kman31 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-02-2005, 05:42 AM
